E53 4.8si Geometry settings
Posted: Wed Jan 28, 2015 10:43 pm
by Mpower
As titled anyone have done the 4 wheel alignment and still have the printouts?
Lee
Re: E53 4.8si Geometry settings
Posted: Thu Jan 29, 2015 1:24 pm
by centurion
I might be able to pull one in over the weekend...
what's the issue - DIY job [i'd advise against] or you plan to take it to a 'reputable' garage and use it for reference?
Posted: Thu Jan 29, 2015 2:14 pm
by Mpower
No I had it done at a garage with the 4 wheel alignment machine but wanted to compare the settings against whats printed for the car as the steering wheel is not quite spot on but car drives fine.
I would appreciate the geometry data if you could pm or post up.
Lee
Originally swapped over from 2 axle air suspension to struts and springs and had told the garage to align everything as 4.8 spec it just to compare so the tyres wont be destroyed in a few months!
Posted: Thu Jan 29, 2015 7:47 pm
by centurion
If the suspension is okay tyres should be fine for good 10-12k+.... Btw, bmw's are prone to steering rack issues so you may as well check that too.
Posted: Thu Jan 29, 2015 8:37 pm
by Mpower
[quote="centurion"]
If you still have the geometry settings it'll be great to see.
