Battery low
mark hamster 28
Battery low
Post by mark hamster 28 » Sat Jan 24, 2015 10:38 pm
Washed my car today then moved it to hoover inside. Left keys in after switched off and then noticed it was beeping and then saw an amber pic of the battery on the sat/nav screen. Is it really flat when this comes on or is this an early warning ? will go for an hour drive 2 mo and hope it recharges it back to full ? Strange as my sat nav dont always come on and after eject and re insert it back in to make it work. Did ask bmw derby if maybe the battery was getting low but i was told things like heated seats and heater will stop working when the battery is low ?? just a bit confused.com lol
::) X5 M Sport F15  3.0D M Sport  ::)
PREV-
New Model X1 Xline 2.0 D 2015
X 5 M Sport 3.0 D (E70) Only been gone 2 days but missed  :(
Ford Focus ST3
Audi A4 Cab Final Edition
Range Rover Sport HSE
535dboy
Re: Battery low
Post by 535dboy » Sat Jan 24, 2015 10:48 pm
They don't like winter!!!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
Re: Battery low
Post by X5Sport » Sun Jan 25, 2015 11:15 am
My X6 does exactly the same.  If you have the ignition on at 'radio ready' but not running, these cars draw a huge amount of power doing nothing - in my case almost 60A.  That canes a 100Ah battery very quickly.
RenoHuskerDu
Re: Battery low
Post by RenoHuskerDu » Fri Jan 30, 2015 10:07 pm
Mine has the gel cell battery, probably due to its Webasto option. Voltage was hovering around 12.4v AFTER a long drive. A trickle charger brings it up to 13.4v but then it drops to 12.6v again after an hour of sitting. I like to see at least 13v resting voltage on my vehicle batteries. Call me a perfectionist.
Hating winter as I do, and seeing a strong battery as my first line of defense, I'm having the German dealer put in a new battery today.  Crikey, the gel cell is expensive! I hope Odyssey makes the bugger.
Re: Battery low
Post by X5Sport » Sat Jan 31, 2015 12:13 pm
6 cells at 2.1V per cell is 12.6V so your battery is fine.  Anything over that usually means you still have stray charges on the plates which need to settle for at least 4 hours.
Charging voltage on an AGM should be around 14.2 - 14.4V, 13.8 on a 'wet battery'
RenoHuskerDu
Re: Battery low
Post by RenoHuskerDu » Sat Jan 31, 2015 12:19 pm
Yep, but 12.4v after a 30min autobahn drive is too low in my book. Call me a perfectionist, but I think my battery was weak. The PO probably ran the Webasto a lot with the timer and/or remote control. The car came from the frosty NE of Deutschland.
Speaking of auxiliary heating, we just bought a Crafter 9-seater which has an Ebersprächer heater for the rear. I have not been able to figure out the German manual entirely, but it does not seem to drain the battery much if at all. OTOH, it does not warm the engine coolant. It only space heats.
Re: Battery low
Post by X5Sport » Sat Jan 31, 2015 3:58 pm
You also have to allow for the fact it takes 20 minutes to put the starting charge you used back into the battery, and that the electrical/electronic systems in the car all use power too with the alternator output being a fixed maximum.
Put it all into play and a 30-min drive is unlikely to give you a fully charged battery.  There's being a perfectionist and then there's the rules of physics & chemistry.
RenoHuskerDu
Re: Battery low
Post by RenoHuskerDu » Mon Feb 02, 2015 2:01 pm
For once I hope you're wrong.  ::)
