Hi all,
I recently tried to swap my air bags over to coils on the rear of my e53 2001. I got everything fine until I needed to put the springs in. They just wouldn't fit in the gap. I tried every angle and even compresse the springs more than was advised. I have since decided to give the car to a mechanic but he seems to think a whole host of things need to come out in order to get them in, is that correct ? Many thanks for any advice.
BMW rear suspension change from air to coil
Post by diatonicbreaks » Fri Jan 16, 2015 8:22 am
diatonicbreaks
Re: BMW rear suspension change from air to coil
Post by Mpower » Fri Jan 16, 2015 9:59 am
Well I got them in by myself by using a bottle jack and wood to expand the space needed to slide the springs in.
The above method works for me and not having a go at your mechanic he must try harder!
Mpower
Post by KGB BORIS » Fri Jan 16, 2015 10:25 am
TBH I removed quite a bit but only because I done the integral links and rose joint bushes and all rear arms at same time, you can get them in if the whole of the rear is off the floor and yes use a lever bar or some wood to lever the arm down and compress the spring then release it when its in the right spot. its tight but not impossible
KGB BORIS
Post by diatonicbreaks » Fri Jan 16, 2015 10:56 am
Ah OK I didn't realise I needed to pry it open so much as the guides I read didn't mention it. I'm far from being mechanically minded !! Thanks for the replays guys really helps. I'll try again before I send it back to the mechanic on Monday.
diatonicbreaks
Post by mattyc » Mon Jan 19, 2015 7:10 pm
Space is tight but if you ratchet the springs down to 25 cm or less they will squeeze in - http://www.xdrivers.co.uk/forum/https:/ ... ic.php?t=8
BMX X5 2005 3.0D
mattyc
Return to “General X5 Forum (E53 1st-gen, 2000-2006)”
Jump to
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
