Few random X5 E53 bits for sale
g60renshaw
Post by g60renshaw » Sun Jan 11, 2015 10:04 pm
Following the sale of my X5 I have found a few bits to sell in the cupboard
1. Radiator fan.  £75
2. Pair of fog lights £40
3. Brand new BOSCH wiper blades £15
4.  CV boot kit £10
5. 4" screen headunit £20
6. All the parts needed to retrofit install of tyre pressure monitoring. £50
All in Wilmslow Cheshire but will post
g60renshaw
Re: Few random X5 E53 bits for sale
Post by g60renshaw » Mon Jan 12, 2015 9:31 pm
Open to offers on all this by the way :)
Dimsum
Post by Dimsum » Thu Jan 22, 2015 10:35 pm
Hiya.
're the tyre pressure monitoring retrofit. Is this diffit to fit?
Many thanks
James
g60renshaw
Post by g60renshaw » Fri Jan 23, 2015 7:17 am
Pretty straightforward from what I have read.  See this link for details http://www.bimmerboard.com/forums/posts/179456
Dimsum
Post by Dimsum » Fri Jan 23, 2015 4:34 pm
Thanks for the link. As soon as I saw words like "splice" it tells me it's not a plug and play which is a shame. Anything electrical and I run for the hills! Was hoping for a straightforward plug n play.
Steamyrotter
Post by Steamyrotter » Wed Mar 04, 2015 2:07 pm
G60Renshaw...
Are any of these still available??
You have PM
X5-D-Sport
Post by X5-D-Sport » Thu Apr 16, 2015 11:03 pm
Tyre Pressure Monitoring retro-fit kit.... still available ??
The electrical stuff isn't a worry... BUT..
Where /  how does the vehicle monitor the pressures, and how is the individual tyre pressure monitored & data sent from the wheel ???  to where does it show ?
Never had this facility on a vehicle before, but it sounds good.
Regards
Grant B
Post by X5Sport » Fri Apr 17, 2015 8:42 am
On most versions (some V8's were different) the TPMS works via the ABS.
This system monitors the wheel rotation speed and if any one becomes different - caused by a flat tyre - then a yellow then red tyre warning symbol appears on the dash.  If you have a button on the lower centre console which looks like a cross section through a tyre with an exclamation mark in it then you have this system fitted.  As it is part of the ABS there is no need to replace anything.
The V8 version uses a transmitter installed inside each wheel and a receiver module.  When the pressure faults then that brings a warning light on.  U.S. Vehicles require this radio based system hence the V8s having it, though for some reason 6-cyl engines use the ABS based TPMS.  These transmitter sensor units do die after a while and need replacing.
There are no pressure readouts.
Steamyrotter
Post by Steamyrotter » Fri Apr 17, 2015 1:01 pm
Regards
Grant B
Sorry Grant..
I got that bit...  :)
:P
This one uses the ABS and triggers a "Tyre Defect" message on the dash...
touring_style
Post by touring_style » Sat Apr 25, 2015 8:30 am
Is the tyre pressure monitoring kit still available???
2002 E53 3.0i Sport Auto
Steamyrotter
Post by Steamyrotter » Sun Apr 26, 2015 4:35 pm
[quote="touring_style"]
Nope.
See above...
touring_style
Post by touring_style » Mon Apr 27, 2015 6:29 am
Steamyrotter - Did you manage to install the kit successfully? Any tips - or was it straight forward like on the link above for the E38 How To guide?
Steamyrotter
Post by Steamyrotter » Mon Apr 27, 2015 5:30 pm
Not got to fitting it yet as just had knee surgery and can't get in right angle.
Doesn't look that straight forward as access is pretty bad!
Just doing the research on alternative pickup points as believe there is an easier location!!!  (Famous last words!)
Post by X5Sport » Mon Apr 27, 2015 5:45 pm
[quote="Steamyrotter"]
Not got to fitting it yet as just had knee surgery........
You need to stopping kicking gearboxes etc!
Steamyrotter
Post by Steamyrotter » Mon Apr 27, 2015 10:37 pm
There is that to it..
O:-)
But it was something a little more sad that led to the requirement!!!!
