Power steering noise/leak
Posted: Fri Jan 09, 2015 10:26 am
Hi all
Not sure if this is a common fault, but when I turn the wheel clockwise I can feel a very slight and subtle vibrate in the wheel, and there's a very slight vibrate sound which you only tune into because you can feel it, it's not loud enough for others in the car to pick up on.
I have noticed when I'm parking, if I out more of a full lock clockwise that there's a line of fluid/oil on the drive way.
I've only recently purchased the car and I topped up the PS reservoir , it doesn't seem to have dropped significantly since but there is a definite trail on fluid on the floor.
Is this a common fault or an easily rectifiable issue?
