Hi all.
got in my car today and the cel was on.
car drives fine so assuming O2 sensor or egt either way want to reset to see if it is a one off.
I hooked up a bluetooth elm code reader to the car but it doesn't seem to read the ecu.
is there a way of manually resetting it?
Also would my lpg conversion mean my obd port would stop working?
b
frustrated with cel
- Steamyrotter
Re: frustrated with cel
Dont think the ELM units work with the E53...
Yes, i have found that out the hard way...
Turns out i have codes
P0348 Camshaft Position sensor A circuit High
P0343 Camshaft Position sensor A circuit High
P0174 System too lean
P1161 Fuel trim additive Bank 2 High
P1341 Multiple Missfire
P1357 Missfire cylinder 8
P1353 Misfire cylinder 6
P1355 Missfire cylinder 7
Any ideas?!
Any ideas?!
Replaced the cam sensor and seems to have fixed codes but now runs a bit rough. Any ideas?
Part and parcel of having lpg. If the gas and petrol are not in perfect harmony, eventually the fuel trims will creep until they reach the limit and you get a misfire with associated CEL or an out of range fault. Either get the adaptions reset using inpa or similar then run it around just on petrol for a while and then get the LPG setup properly.
2002 4.4 cooking on gas
