Transmission Failsafe Program
mattyc
Post by mattyc » Thu Nov 20, 2014 7:16 pm
I get this error sporadically. Basically when accelerating hard I get a strange whine from the gear box then get thrown into Transmission Failsafe Program. I think the car sticks the gearbox into failsafe mode to protect the gearbox.
Here is my dilemma - we have a warranty on the car. I have it booked in with Bavarian next week for diagnosis.
If the diagnosis shows the fault is with the gearbox and it needs repaired I can claim back diagnosis and cost of repair.
If diagnosis shows it is something else causing the issue I have to fork out Bavarians £100 / hour fees with no claim back.
Can anyone give me advice on this error?  Have the full error codes from bmw scanner 1.4.0 but can't attach?
BMX X5 2005 3.0D
Re: Transmission Failsafe Program
Post by X5Sport » Thu Nov 20, 2014 10:26 pm
You need to upload the images to a photo share site and cross link to them.  I use Photobucket, and there are plenty of others.  Codes need to be from the gearbox itself.
You need to get it looked at ASAP.  It could be the gearbox or transfer box, or a diff.
mattyc
Post by mattyc » Thu Nov 20, 2014 10:31 pm
Thanks Richard. Error codes pasted out below. I think I will maybe try and get a local specialist to diagnose first. If he points in the direction of gearbox failure I can take the warranty route.
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
EWS  ->  13/01 - Toleration of changing code increased, key 1
          0F/3F - Power on reset
          23/FF - Toleration of changing code increased, key 2
          20/01 - Wrong identification, key 2
          0E/01 - DME changing code XOR-error
          10/01 - Wrong identification, key 1
A/C  ->  21/01 - Park heating Locking valve, Latent heat storage system Cut off valve
SRS  ->  Shadow-memory:
          51/08 - Fault lamp, short circuit to negative or open circuit
          50/20 - Power supply, undervoltage
IKE  ->  BD/90 - Electronic braking-force distribution
          8D/90 - EGS signal line disturbed
LCM  ->  Shadow-memory:
          57/01 - Level control system
          59/06 - Transmission failsafe program
          62/03 - MRS seat occupancy recognition fault
          93/06 - Right brake light
ZKE  ->  A7/04 - Mirror, potentiometer horizontal or cable, passenger's door
          95/06 - Interior security: fuse or cable
          A5/06 - Mirror, potentiometer horizontal or cable, driver's door
          6B/01 - Relay sticking to ground, power window motor, rear, driver's side, closing
          Shadow-memory:
          83/03 - DWA-Alarm: door contact, driver's door
          80/01 - DWA-Alarm: Terminal R
          8B/21 - DWA-Alarm: rear window or interior security
PDC  ->  11/C6 - Converter, rear right
          15/86 - Converter, front right
          16/C8 - Converter, front centre left
MID  ->  03/0A - No valid status response of TELEPHONE
VTG*  ->  54C6/31 - Oil abrasion
SHD  ->  A092/21 - SHD normalization error
          A0A2/21 - SoS normalization error
          A088/03 - Switch error
          Shadow-memory:
          9541/5F - SHD SKB activation
          9440/1F - Panic mode activation
          9540/42 - SHD Manual roof movement
          9441/01 - Manual initializing
          9509/41 - SHD Sliding curve
          950A/61 - SHD Lifting curve
          9609/A1 - SoS Sliding curve
          9443/21 - Cancelled initializing
          9607/A2 - SoS Position lost, power failure
          9608/A2 - SoS Position lost
BMX X5 2005 3.0D
Post by X5Sport » Thu Nov 20, 2014 10:36 pm
The VTG one is relevant.  That's the transfer case.  It needs an oil change as a minimum.  It isn't a lifetime oil so has exceeded its useful life.
See this thread.
R
mattyc
Post by mattyc » Thu Nov 20, 2014 10:49 pm
Thanks Richard. Do you think the gearbox would go into "Transmission Failsafe Program"  if an oil change is required?
Will chat to the local guy tomorrow.
BMX X5 2005 3.0D
mattyc
Post by mattyc » Sun Nov 23, 2014 7:28 pm
Chatted to a guy at Autotechnic in Belfast on Friday past. Extremely helpful and has advise that getting an oil change is definitely the first thing to do (Bavarian would advise the same thing apparently). He also mentioned that if you hear a yelp from the gear box (which I do) then oil change is vital.
Booked in for 1st December will let you know how I go.
BMX X5 2005 3.0D
centurion
Post by centurion » Tue Nov 25, 2014 5:23 pm
I looked at the following the other day and I'm tempted to do the same on my car... any advise re whether listed parts are sufficient or if anything else needs to be added?
http://www.ebay.co.uk/itm/221522006173? ... EBIDX%3AIT
for my info... how long does it take to complete the job / avg. cost of doing so? Thx
