P0128 error code - coolant temp sensor
centurion
Post by centurion » Tue Nov 18, 2014 5:30 pm
i did my first scan today using elm327 and Torque phone app... all fine apart from abovementioned error which seems to be pointing to CTS ;).
i checked coolant level (fine), no obvious leaks on the pipework and something to note that temp is at the 'middle point'... all in all fine as it does take good 7-10min to reach that level and i think that's std  avg time to reach optimal working temperature on any car. Pls correct me if I'm wrong :)?
Other than that I'd certainly change the coolant temp. sensor and was wondering if anyone can advise how easy/difficult is it to do 9and more importantly where is on 4.8is) :xmasgrin:?
kkx5
Re: P0128 error code - coolant temp sensor
Post by kkx5 » Tue Nov 18, 2014 7:34 pm
centurion
Post by centurion » Tue Nov 18, 2014 8:03 pm
Ta... whereabouts is that in the engine bay :)?
kkx5
Post by kkx5 » Tue Nov 18, 2014 8:15 pm
centurion
Post by centurion » Tue Nov 18, 2014 9:36 pm
cheers... much appreciated...
centurion
Post by centurion » Tue Nov 25, 2014 5:29 pm
I'm getting my part tomorrow and was wondering how easy/diff. is it to replace?
anything to worry about re coolant/hoses etc? Thx
centurion
Post by centurion » Wed Nov 26, 2014 8:33 pm
hi I tried replacing one today but it seems that coolant is leaking badly when I tried to unscrew the sensor :). Guess I'm doing something wrong...  Any hints on how to prevent that or best practises to accomplish this easy (or not so) task :)? Ta
kkx5
Post by kkx5 » Wed Nov 26, 2014 9:55 pm
1.Drain system below water pump level or
2.Swap sensors very very quick :)
centurion
Post by centurion » Wed Nov 26, 2014 11:47 pm
cheers... re #1, where abouts is the drain plug (for coolant) :)?
in additon, while trying to dismount the sensor a hose connected to intake manifold had snapped (due to age and no longer rubbery) and would need to replace it. Does anyone know what it is it used for (see attached image)?
centurion
Post by centurion » Fri Nov 28, 2014 4:05 pm
Any clues re small pipework attached to the air duct :)?
