Name that hose
mattyc
Name that hose
Bit of an exhaust leak in the engine bay and I think the hose in the attached picture is the culprit. Exhaust smell coming through heater and can see some fumes coming from drivers wheel arch. Can anyone name the hose for me? It's the bendy silver section that attaches to the solid silver steel pipe.
If it's a non-exhaust hose then any pointers would be appreciated.
*Image removed as confusing
Cheers, Matt
Cheers, Matt
BMX X5 2005 3.0D
Re: Name that hose
That's one of the air conditioning lines. It contains compressed gas so is unlikely to be the source of your problem.
The fresh air inlets are all under the top section of the scuttle - where the grilles are up top in front of the screen.
Oh, and
to the Forum Matt
Oh, and
mattyc
Re: Name that hose
Thanks Richard. OK exhaust definitely not coming out of that!
Any pointers as to where it could be coming from? Manifold, exhaust etc. sit below that pipe? Odd I can see fumes coming out of the drivers side wheel arch at idle.
Matt
Matt
BMX X5 2005 3.0D
Re: Name that hose
The exhaust manifold is that side and there have been instances of cracked/split manifolds which would explain the smell & fumes.
mikem
Re: Name that hose
Almost certainly exhaust manifold
- Stevejspm
- Contact:
Re: Name that hose
Just had my manifold changed today for that very reason. Streaming eyes after sat in traffic! All good now though & the old manifold looked cracked in about 4 places.
centurion
Re: Name that hose
...is manifold crack(ing) common to all models or predominantly diesels?
- davesavage257
Re: Name that hose
From what I've read it's a reasonably common occurrence on all BMW 6 cylinder diesels with the fabricated rather than cast manifolds.
Dave
2003 BMW X5 4.6iS Auto
2007 '57' Saab 9-3 Aero 2.0T Auto
Dave
2003 BMW X5 4.6iS Sapphire Black
mattyc
Re: Name that hose
[quote="Stevejspm"]
Dare I ask how much a new manifold and labour is? Have seen a few guides and it seems to be extensive work.
BMX X5 2005 3.0D
- kkx5
Re: Name that hose
Cracked exhaust manifold on 3.0i? Very unlikely. Leaking rocker cover gasket is your problem... oil dropping on exhaust manifold.
Chrisw4266
Re: Name that hose
[quote="kkx5"]
Have to agree 3.0i probably leaking rocker gasket caused by a failed ccv pressure in the rocker cover. Try removing the oil filler cap with the engine running. Should be a slight vacuum if it blows the cap off or has a massive vacuum then the ccv is shot and needs replacing.
mattyc
Re: Name that hose
[quote="mattyc"]
3.0D folks I should have said. Cheers for the help.
I think the confusion is that that photo you've posted looks more like a 3.0 i engine not a diesel, I took it to be a petrol As I couldn't see the Webasco, and the engine covers looked different to my old 3.0d, more like my 530i
mikem
Re: Name that hose
If it's a d I'd put money on it being the manifold (£150 for a cast replacement) and about 3hrs labour.
To confuse things, that picture above shows a petrol engine ???
mattyc
