headlight washer jet removal?
Posted: Tue Oct 21, 2014 5:56 pm
by fenj66
hi guys, ive noticed my headlight jets are not working when i pull the wash stalk, im sure they used to come on for a quick blast when the windscreen was washed with headlights on?
anyhow, does anyone know how to remove the jets from the front bumper to give then a good clean out
i know there was an old link to spaghetticoder for this but that site looks dead now!
cheers!
Re: headlight washer jet removal?
Posted: Tue Oct 21, 2014 7:23 pm
by gazg60
I had the same problem . Turned out that the pump filter in the washer bottle was completely blocked with a slimey gunge . Once cleaned and re-fitted it works fine .
Posted: Tue Oct 21, 2014 7:26 pm
by jason1872
The headlights don't get washed with every windscreen wash,think its every 1 in 5 or something like that.
Posted: Tue Oct 21, 2014 7:40 pm
by fenj66
Ive cleaned the gunk from the reservoir filters. But still no luck with the head light jets. I need to trace the water pipe from the pump to the jets and look for a problem.
Posted: Wed Oct 22, 2014 2:18 pm
by fenj66
well. i think ive found my problem, the pipe to the headlight jets appears to be leaking under the drivers side headlight.
unfortunatley i couldnt work out how to remove the headlight to gain access to the pipework under there.
i removed the 2x8mm top headlight screws and the 2x8mm bottom screws the headlight pulled forward about 4 inches but i couldnt get it free of the bodywork beyond that. any ideas folks??
Posted: Wed Oct 22, 2014 3:02 pm
by X MAN
[quote="fenj66"]
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=2
The pipework going to the washer jets may have worked loose ( it was on mine ).
Pic 7 in the link ( red arrow pointing to pipe ) may be your culprit . Unfortunately bumper off job
or in your case remove all fixings and pull bumper slightly forward to gain access to the pipework,
re attach pipe and push bumper back in place. No need to remove headlight.
