Oil consumption
kamb
Oil consumption
Post by kamb » Mon Oct 20, 2014 10:46 am
I have covered approx 5000miles since last oil change upon checking dipstick level today it was on minimum level
I know they burn oil more than other cars but is this normal?
No oil leaks seen only bit of smoke at start up which everyone says is normal check other posts
Re: Oil consumption
Post by Raj » Mon Oct 20, 2014 10:52 am
Which variant do you have again?
My 4.8 gets through oil but it is normal.
kamb
Re: Oil consumption
Post by kamb » Mon Oct 20, 2014 11:06 am
It's 3.0d
CondorX5
Re: Oil consumption
Post by CondorX5 » Mon Oct 20, 2014 11:12 am
BMW dealer recently advised me that adding 1l oil every 600 miles is normal - I have a 4.8 though, they do use oil.
Re: Oil consumption
Post by X5Sport » Mon Oct 20, 2014 11:50 am
That sounds normal for the 3.0d.  Well within the BMW spec.  These engines do use a bit, and mine (218bhp variant) certainly did.
TimX5
Re: Oil consumption
Post by TimX5 » Mon Oct 20, 2014 12:35 pm
My 06 3:0d used 1ltr of oil after covering 1650 miles on holiday touring with a 6 birth caravan ,  I was abit concerned also but after reading up on the forum it seems quite normal.
kamb
Re: Oil consumption
Post by kamb » Mon Oct 20, 2014 12:42 pm
Cheers it took just over 2l to get to max on dipstick so
Sounds about right
Good job I stocked up on oil whilst it was cheap at eurocarparts few months back
kkx5
Re: Oil consumption
Post by kkx5 » Mon Oct 20, 2014 1:09 pm
[quote="CondorX5"]
1L every 600miles is normal?? 10L every 6000miles...Tell them they are nuts...N62 dont use oil. Valve seals are gone on yours.
Re: Oil consumption
Post by Raj » Mon Oct 20, 2014 1:14 pm
[quote="kkx5"]
[quote="CondorX5"]
Might be worth checking if it wasn't just a typo before going off on one as per normal.
Re: Oil consumption
Post by Raj » Mon Oct 20, 2014 1:15 pm
[quote="kamb"]
It's 3.0d
Then it's normal tbh.
Smeeagain
Re: Oil consumption
Post by Smeeagain » Mon Oct 20, 2014 1:20 pm
[quote="kkx5"]
[quote="CondorX5"]
I think you're wrong - I would say its reasonably normal. Most folk don't bother to check oil levels these days and simply expect it to last between services. Also depends on your style of driving of course
kkx5
Re: Oil consumption
Post by kkx5 » Mon Oct 20, 2014 1:32 pm
It's not normal for n62. I've noticed some of You on this forum don't have a clue about engines, yet they claiming, I'm wrong >:( .You dont have to top oil up between services.
Re: Oil consumption
Post by Raj » Mon Oct 20, 2014 1:48 pm
[quote="kkx5"]
Tbh I think it's wrong to say that you should never need to top up oil between services. Every engine will burn some oil so I can't see how it can go 15k miles for example without topping up. I agree every 600 miles is excessive though hence thinking it was a typo possibly.
kkx5
Re: Oil consumption
Post by kkx5 » Mon Oct 20, 2014 1:54 pm
What kind of driver is changing oil every 15k? 10k is max. 1l per 10k is normal.
Re: Oil consumption
Post by X5Sport » Mon Oct 20, 2014 2:01 pm
[quote="kkx5"]
Those with Condition Based Servicing.......up to 20k!  I've had several cars, and not just BMWs, with CBS and the change interval varied with driving style.  Only if the WRONG oil was used did it drop to 10k intervals.
Locked
