Against the grain - X5 2004 3.0D
Moe
Post by Moe » Tue Oct 14, 2014 9:28 am
Not your usual 20 year old just bought a X5 3.0D
This is my 4th car since January:
Some issues that need to be sorted, if anyone can help with the issues?
Horn doesn't work
One heat seat doesn't work
Parking sensors
Folding mirrors - they fold but then unfold by them self
Rear doors don't open from outside, handles a bit iffy.
And the sat nav thinks I'm in France lol
Re: Against the grain - X5 2004 3.0D
Post by X5Sport » Tue Oct 14, 2014 10:52 am
Welcome.
Have a careful check of those wheels too. If the tread is clear of the wheel arch measured vertically then you need the extensions too otherwise you'll fail the MOT as well as Construction & Use Regulations. It looks very close from the pictures but you might be OK due to the angles you took the pics at.
Satnav isn't the OEM one but an aftermarket fitment so it could be a GPS fault.
Seat heating failure may be a connector under the seat or a fuse, but could also be element failure in which case you need a new seat cover.
There's a fix on here for the mirror issue, and lots of advice about the PDC fault as both are pretty common.  PDC could be a sensor, wiring, or control unit.
Door handle fixes also on here....could be broken lock carriers both sides.
The search facility will find you a lot of what you need.....
Sanj
Post by Sanj » Tue Oct 14, 2014 12:42 pm
:hi:
Post by AW8 » Tue Oct 14, 2014 1:32 pm
Welcome.
On top if last reply the  horn issue likely a connection issue as I think it's twin tone so unlikely both have packed up. Worth checking fuse for starters other than that competent use of a basic circuit tester may be sensible. Be careful messing near airbag and get a professional to check connections there in any doubt. Hope past airbag activation not a factor.
From pics car looks ok but the wheels make the car look cheap and tacky IMO.
Would be interested to know how much your insurance costs p/a albeit appreciate you may not wish to share this info.
Moe
Post by Moe » Tue Oct 14, 2014 7:19 pm
I'm paying about £1500 a year insurance.
Ordered two microswitches today, as one was missing, so hopefully that's the mirrors sorted.
Getting the horn and door handles looked at tomro.
Starting to come along now.
Need to get this remapped
Sanj
Post by Sanj » Tue Oct 14, 2014 7:28 pm
Are you doing any DIY? Will save you lots...
Labour is always the biggest bill.
Post by AW8 » Tue Oct 14, 2014 10:09 pm
£1500 not bad relative to your age - I hope it's fully comp though.
Please post a link for the switches - even if you got it off the other thread- it will help others in future.
Post by Horizon » Tue Oct 14, 2014 10:42 pm
My 20 year old son also drives a 59 plate BMW. This is because he pays £25 per week keep. When I was his age I paid a third of my wage to my parents. That's why they never leave Home these days. But spend all their money on cars instead.  I was on my second house when I was 23 :)
Moe
Post by Moe » Tue Oct 14, 2014 11:09 pm
It's much harder when I don't have a job  :noexpression:
The mirrors I'm doing them myself, and the satnav I ordered a new navigation cd and that should do the trick.
Need someone to do the sensors
Post by Raj » Thu Oct 16, 2014 11:12 pm
Welcome aboard.
IceQueenX
Post by IceQueenX » Fri Oct 17, 2014 9:40 am
Welcome to the forum, Moe. Car looks good.
iff26
Post by iff26 » Sun Oct 19, 2014 8:43 am
Door handles get from eBay, I did and they work perfectly, in BMW £70 and odd £30 or less in eBay and my local indy said that they same make as he bought his from BMW!
Shouldn't be more than 1 one job unless u go with diy with little help from YouTube!
Nice motor and welcome!
X5 4.4is  EX Carbon Black
Post by AW8 » Sun Oct 19, 2014 3:41 pm
[quote="Moe"]
Been working for nearly 30 years and have an older car than you.....Clearly I must be a slacker or doing something wrong with my mans maths :)
Moe
Post by Moe » Wed Oct 22, 2014 4:16 pm
[quote="AW8"]
[quote="Moe"]
Become a drug dealer lol
Few issues I need help with:
Steering wheel vibration when I drive past 60, had it hunter balanced and suspension parts are okay. Could it be the 22" tyres and low profiles?
Also sometimes the car takes a while to get to half way on temp gauge. No codes, should I be worried?
Post by X5Sport » Wed Oct 22, 2014 5:40 pm
Yes, or suspension wear, or bush wear, or bent rims.
Might be thermostat heading towards end of life.
