what's the power distribution from front and back?
celica
Post by celica » Thu Oct 09, 2014 3:06 pm
Re: what's the power distribution from front and back?
Post by X5Sport » Thu Oct 09, 2014 5:17 pm
Roughly 60:40 rear:front, but the xDrive system can shift that ratio to all rear or all front or anywhere in between depending upon what it detects in terms of wheel spin etc.
Pre-Xdrive cars in the E53 (pre Facelifted) are fixed 60:40.
celica
Post by celica » Thu Oct 09, 2014 10:25 pm
Which tyres on say normal use would wear out quicker
Fronts because of engine weight
Or rear because more drive?
Post by Graeme » Thu Oct 09, 2014 11:24 pm
Over 104500miles now, and on 4 sets the rears wear fastest.  Pressures are crucial - a couple of pounds more in the front helps stop excessive wear on the outer edges.  Never over-inflate the rears when the car is used unloaded to prevent the centre wearing quickly.  But, conversely, if the back of the car is loaded, e.g. with a caravan, and the rears aren't pumped up according to the recommendations (see plate on front driver's door pillar) the inside edge of the tyres will wear quickly if the car is used on twisty roads such as in Scotland!
celica
Post by celica » Fri Oct 10, 2014 10:45 am
thank
i'm not looking forward to replacing the 315 35 20 on the rear lol
kkx5
Post by kkx5 » Fri Oct 10, 2014 8:45 pm
X-drive can not shift all to front,  you know that Richard...
Post by X5Sport » Fri Oct 10, 2014 10:59 pm
I'm only going from the official documents......it might be 99.5% in reality but no figure is quoted, only that the torque can be shifted 'all front or all rear depending upon the driving conditions'.
kkx5
Post by kkx5 » Sat Oct 11, 2014 12:47 am
It can be max 50% to the front... Ok, lets make it very clear 0%~50% front 0%~100% rear.. Fixed 0%-100% parking,  0%-100% over 110mph ;)
