LED rear lights for 4.8is
Posted: Tue Oct 07, 2014 5:04 pm
by centurion
hi guys,
any suggestion re rear LED lights and where to source them from? i'd like to replace both (inner and outer)on each side (obviously :)) as they are cracked.
Ta
Re: LED rear lights for 4.8is
Posted: Tue Oct 07, 2014 8:12 pm
by Sanj
Lots out there and issues with all of them. They need a resistor...
Google came up with these.
But we have a few threads on here too - Link 1 & Link 2
Posted: Tue Oct 07, 2014 8:18 pm
by RoShamBo
I have been looking at getting a set of these LED's :
http://www.mstyle.co.uk/acatalog/info_D02LB043.html
Maintains the standard look of the rear lights (with a longer reversing lens) so doesn't look too aftermarket.
Ro.
Posted: Tue Oct 07, 2014 8:24 pm
by Horizon
[quote="Sanj"]
http://www.ebay.co.uk/itm/290687128034
I bought off this seller to overcome a problem with a reverse camera / numberplate light that I bought, it came with an LED which my Canbus flagged as a blown bulb, fitted one of these, sorted
Posted: Tue Oct 07, 2014 9:55 pm
by centurion
Cheers guys... That sounds like a plan.
Ro - ill probably go with your suggestion as it does look like stock item albeit ffwd-ed couple years to present times :).
If only bm had thought of replicating e39 concept of rear light on e53's...
Posted: Tue Oct 07, 2014 10:22 pm
by centurion
Ooops hit send too soon (out of excitment)...
Guess one from mstyle is (or should be) uk legal/ mot pass and is e marked etc ;)?
Posted: Wed Oct 08, 2014 2:14 pm
by centurion
hi guys,
I spoke to Nathan from Autoenhance and he advised that LED's would flicker ever so slightly in normal light on mode and should work fine when brakes are pressed... any hints on how to resolve this (heard some rumours about the resistors that fix this issue)?
ta
Posted: Wed Oct 08, 2014 5:49 pm
by Raj
[quote="centurion"]
hi guys,
ta
Capacitor inline will sort it. That's what I did with mine.
Posted: Wed Oct 08, 2014 6:45 pm
by centurion
Guess one on each side?
Posted: Wed Oct 08, 2014 8:29 pm
by Horizon
You have to match the original resistance of the bulb / bulbs. For example if the original rear lamp uses two 5 w bulbs for the side lights on that side, you would need a load resister of 10 w. This is to fool the bulb check on the canbus system that there are 2 x 5w bulbs on that line. Same for the indicator , match the bulb resistance, same for the brake light .
Alternatively the bulb check can be un ticked in the menus in Scanner 1.4.0 this may work, has anyone tried this with LED rear lights?
Posted: Wed Oct 08, 2014 8:32 pm
by centurion
Cool... I think indicator is a std bulb so that would be fine. Could anyone share the diagram or post a pic Where to splice the wire/s and how to connect the resistor?
Once again much appreciated for all your feedback guys...
