				Mirror puddle lights
				Posted: Sun Sep 28, 2014 9:00 am
				by Storm
				Hi just a quick one how do you change bulbs in mirror puddle lights thinking of upgrading bulbs
				Re: Mirror puddle lights
				Posted: Sun Sep 28, 2014 1:31 pm
				by TimX5
				Think you have to remove the mirror back to gain access.
				Posted: Sun Sep 28, 2014 9:42 pm
				by Sanj
				[quote="TimX5"]
Correct - have a butchers at threads (with pics) on this already.
				Posted: Tue Sep 30, 2014 9:20 pm
				by Chrisw4266
				Just had my mirrors in pieces (on going folding issue) and can tell that you that LED/SMD bulbs don't work, you'll need can bus compatible ones as mine powered up but immediately shut off. Its because they fade on and off and are controlled by the lighting module. In answer to your original question use a thin flat plastic trim tool prise at the lower corner of the trim nearest to the window. Once it's loose gently  work along the bottom edge and up the side, then pull the top section away. It uses a 501 capless type bulb and is on a white 2 pin plug. Unclip the connector and twist the bulb holder out of the lense.
				Posted: Tue Sep 30, 2014 10:12 pm
				by Steamyrotter
				Go one weirder than that...
Leave a normal incandescent lamp in one side and a LED in the other and it works ok!!!!
				Posted: Tue Sep 30, 2014 10:18 pm
				by Chrisw4266
				[quote="Steamyrotter"]
spooky didn't try that one, must be a current pulling issue. BMW have some crazy ideas when it comes to lighting circuits.
				Posted: Wed Oct 01, 2014 1:09 pm
				by Steamyrotter
				From my measurements it appears (at the mo..) that they are wired in series with each other!!!
Need to test a little more, but is the only way i can explain what i have seen so far!!
				Posted: Wed Oct 01, 2014 3:24 pm
				by Chrisw4266
				Sounds about right need a wiring diagram to confirm
				Posted: Mon Oct 27, 2014 11:01 am
				by centurion
				on this topic... I popped to BMW over the weekend to buy one and they said it comes with a mirror cover (in prime grey). A bulb or bulb holder/lamp cannot be bought separately... total cost of mirror cover+ bulb )incl. of VAT) is 50.49.
as for mods I've seen some used SMD's (with resistors) or facelift E53 as well as 'projector' lamps with BMW or M logos etc. Not sure re How to's and wiring diagram is applicable but it 'can be done'
cheers
				Posted: Tue Oct 28, 2014 10:16 pm
				by Chrisw4266
				Smds with resistors should work. Projectors may need the hole drilling out.
