RB's stained/pitting again.
Posted: Mon Dec 27, 2010 8:36 pm
by x555
So i finally managed to give the x a quick wash today after all the snow buggering of and me feeling a little better
But it wansn't long before i realized what i had earlier thought was true..............the dreaded running board pitting was back because of all the shi@y weather and not being able to wash it beast
So it looks like getting out the wheel cleaner and giving them bad boys a good scrubbing with plenty of elbow grease.I did this an age ago and they have kept well with more frequent washing
For info my RB's are on a 54 plate and pit quite badly when left for a while..........i'm sure Sanj's and Pewters are pre 54 reg and are made of a different material that doesn't stain/pit as much.
My x was so dirty it looked like had grafite grey wheels from a distance...........and they looked pretty good
Posted: Mon Dec 27, 2010 9:23 pm
by BL02WAS
looks a state to me!! and the wheels!! what are they?? they look tiny?? 19's i take it???
Posted: Mon Dec 27, 2010 9:27 pm
by ITBarbie
Mine were exactly the same yesterday very pitted. As you may remember I took all the plastic plugs off and wire wool'd the lot in the summer. I certainly did not want to repeat that at -1 so I got put the brasso on and prepared to give it a good rub. Being a woman I got bored after about 5 mins and used my wonder wheels. Amazing difference they are back to normal and I didn't even chip my nails
Why go to all that effort eh. I do need a good recommendation though for a sealer?
Re: RB's stained/pitting again.
Posted: Mon Dec 27, 2010 9:30 pm
by CondorX5
I've noticed mine are showing that same measles-type pitting and staining now - the previous X, which was a 2003 early facelift, didn't suffer from it at all. What product are you using Penny? I don't think I fancy the wire wool and removal of all those wretched little plastic black jobbies........
A job to do when it returns from the dealer eventually; its the least of its problems at the moment
Posted: Mon Dec 27, 2010 10:01 pm
by ITBarbie
I used wonder wheels. Left it on for a few mins after agitating with the rough side of kitchen sponge and then rinsed off. Simples
Posted: Tue Dec 28, 2010 8:02 am
by x555
[quote=""BL02WAS""]looks a state to me!! and the wheels!! what are they?? they look tiny?? 19's i take it???
Sent from my iPhone using Tapatalk[/quote]
stop flappin yer gums again fish head and sort out that webasto before the summer comes
mine has been lovely throught this cold spell hhhhhmmmmmm warm defrosted windows
now go and annot your neigbours with your beeping alarm and flashy lights
Posted: Tue Dec 28, 2010 8:05 am
by x555
[quote=""ITBarbie""]Hi
+1 same here i used wheel cleaner (can't remember which make)and they came up really good and lasted with regular washing.So i will go down the same route again.I heven't used a sealer of any kind so again thoughts/ides would be good
Posted: Tue Dec 28, 2010 12:58 pm
by BL02WAS
haa haa!!! ok ok, thing is though you should have plenty of wheel cleaner left over considering you are only running 19's! the bottle should last you a life time!! with regards to protecting the sills has anyone thought of using the alloy wheel protective wax which they say to apply when wheels are brand new or after good clean etc??
Posted: Tue Dec 28, 2010 8:12 pm
by ChewingBacca
I used wonder wheels. Left it on for a few mins after agitating with the rough side of kitchen sponge and then rinsed off. Simples :[/quote]
Is Wonder Wheels OK on the black studs or did you remove them this time also?
Posted: Tue Dec 28, 2010 8:32 pm
by ITBarbie
No I left the black studs on this time and just sprayed over them.
Posted: Tue Dec 28, 2010 9:00 pm
by CondorX5
Must get off to Halfrauds for some Wonder Wheel or look for it online......those measly spots on the Running Boards really spoil the look (well at least they detract from the puny 18"winter wheels!!!)
Posted: Tue Dec 28, 2010 10:03 pm
by ITBarbie
My large Tesco store stock it so it may be worth a look when you're next in.
Posted: Tue Dec 28, 2010 11:44 pm
by Raj
Wonder Wheels can be sourced from Asda even. It is great stuff for jobs like these. Will be doing mine on Thursday along with the rest of the motor as it is a state. Did think about using poorboys wheel sealant as a layer of protection but not sure if it will work or not.
Posted: Wed Dec 29, 2010 12:19 am
by ChewingBacca
Thanks ITBarbie, my RB's are in a bit of a state due to the road salt. Will give this a try.
Posted: Wed Dec 29, 2010 12:58 am
by Rusty
I am looking into having my RB's refurbished after the winter, so will share as and when I get them done. In the mean time, I just use a good black wax on them when cleaning the plastic. Seems OK so far.
Don't you just hate this weather?
