Newbie and a silly question!
noxid1969
Post by noxid1969 » Wed Sep 17, 2014 4:13 pm
Hi everyone, bought myself a 57 plate E70 3.0D SE with lots of toys on it after getting bored with a VW. The car is amazing lots of fun on short and long journeys, I commute 140 miles a day, not evey day as I couldn't afford the fuel! Over the past 3 weeks though the aircon stopped working so I have got the car booked in next week for diagnostics. But today I had to brake very hard, when the traffic lights went red and suddenly the aircon started working again.
So is it
a) a miracle
b) a coincidence
c) There is something mechanical in the aircon (like a mechanical flap) that I have freed off after continued hard accelarations
d) There is likely to be a very expensive electrical reason!
Steve
Re: Newbie and a silly question!
Post by X5Sport » Wed Sep 17, 2014 5:04 pm
Or it could just need regassing.....
noxid1969
Post by noxid1969 » Wed Sep 17, 2014 5:15 pm
I am assured from the last check 4 weeks ago that the gas was okay, is it that sensitive to the level?
Post by X5Sport » Wed Sep 17, 2014 5:42 pm
Shouldn't be.  If the previous owner didn't use it much then it could have been a bit sticky....
I never have mine off.  It uses so little extra fuel on a diesel with the spare torque....
noxid1969
Post by noxid1969 » Wed Sep 17, 2014 7:28 pm
Sticky I can cope with! :)
Always leave it on as well, didn't buy the car for its economy! just the fun!
Sustanon250
Post by Sustanon250 » Wed Sep 17, 2014 7:41 pm
[quote="noxid1969"]
Quite often I prefer the windows open , in which case, the aircon should be off .
2014 BMW X6M (the toy)
2004 Porsche 911 (996) turbo (the garage queen)
2015 VW Touran (the daily)
goose
Post by goose » Fri Sep 26, 2014 10:54 am
That's very weird.. I have my air-con on most of the time, and when I have to brake hard, it goes off for a second or two whilst the car settles, and then it comes back on and is fine?!?
Will be interested to see what the answer is to this one.
cheers,
goose
_______
2008 X5 3.0sd M Sport - Carbon Black - Evolution remap
1972 VW Karmann Ghia Coupe - Sunburst Yellow
mark hamster 28
Post by mark hamster 28 » Fri Sep 26, 2014 4:39 pm
noxid1969, any updates on this since you posted this ?
::) X5 M Sport F15  3.0D M Sport  ::)
PREV-
New Model X1 Xline 2.0 D 2015
X 5 M Sport 3.0 D (E70) Only been gone 2 days but missed  :(
Ford Focus ST3
Audi A4 Cab Final Edition
Range Rover Sport HSE
noxid1969
Post by noxid1969 » Sun Sep 28, 2014 6:15 pm
Update.
There was too much aircon gas/fluid in the system (quoted as over by 200grams). Garage were really good and checked and cleaned all the sensors at the same time. They are also getting their equipment recalibrated.
mark hamster 28
Post by mark hamster 28 » Tue Oct 14, 2014 8:38 pm
didn't realise you could over fill them but great news.
PREV-
Ford Focus ST3
noxid1969
Post by noxid1969 » Tue Oct 21, 2014 3:33 pm
I've got the same problem again, no aircon! Noticed yesterday in the rain that my windows were steaming up and even using the screen demist couldn't get rid of it all. I have no codes so I am at a loss to what it can be where the aircon comes and goes. How does the aircon pump engage, is it belt or clutch? Are they prone to intermittent faults?
Post by X5Sport » Tue Oct 21, 2014 10:46 pm
Clutch.  Needs to have the snow symbol light on and recirc either off or on auto and the system on auto.  That should keep you steam free.
Gas is lost steadily if the system is not used.  Check the system by running the temp all the way down and make sure it is cooling.
noxid1969
Post by noxid1969 » Thu Oct 23, 2014 9:14 am
Richard,
  I think there is an intermittent problem with the aircon as it is not cooling properly (or at all at the moment) the fact it comes and goes associated with either heavy braking or other such event makes me think that either there is a dry joint/ failing connection or a mechanical issue. There are no codes reported and frustratingly every time it goes into the garage it starts working again.
I leave the system on all the time (Auto) but it is not doing what it should and the steaming up of the windows (even using the demist button) should not be happening if the aircon is working properly, I had been lulled into thinking the last fix had worked because the outside temperature dropped. Will let you know what happens with the garage.
Steve
Post by X5Sport » Thu Oct 23, 2014 10:50 am
Could be.  The only other quick checks might be that the compressor is actually engaging when you press the button.
After that it is a case of taking things to bits.... :(
Be interesting to know what it is once you get it back.
noxid1969
Post by noxid1969 » Tue Oct 28, 2014 2:53 pm
Richard,
The compressor was not engaging even though all the lights were on and there were no errors. The compressor was 'reinstalled' using the software and lovely cold air started to come out. Garage thinks it might be the control unit that is at fault but we are waiting to see if it fails again. But for the moment it is all working as advertised.
Steve
