im sure they were once rubber pipes
Ryoken
Post by Ryoken » Mon Sep 01, 2014 4:27 pm
went out last night to take a few pics of the car, noticed the plastic cover on top of the engine was loose
took it off  to see how it fastened, and noticed this :)
now im positive, they were once pipes
steveImage
2002 e53 4.4  tempremental
Re: im sure they were once rubber pipes
Post by X5Sport » Mon Sep 01, 2014 8:58 pm
Well that won't help with engine performance! :o
Post by AW8 » Mon Sep 01, 2014 10:11 pm
Will need changing - arguably should be checked as a service item.
Keep an eye on rocker gaskets .... Chances are they will need attention soon  if not already sorted.
Ryoken
Post by Ryoken » Mon Sep 01, 2014 11:23 pm
had a quick looksie round and there isnt any oil on the rockers . its actually quite clean in there . obviously apart from this  :)
oh x5sport , what do you think this would cause performance wise?
poor running , high fuel ?.
Post by X5Sport » Tue Sep 02, 2014 10:44 am
Not knowing what the pipes do I can't tell you, but I would expect that if they have vacuum or gas flow then that could upset the engine as the 'system' isn't sealed correctly any longer.
Ubatoid
Post by Ubatoid » Tue Sep 02, 2014 6:51 pm
They are part of the crank breather system. It's time for a service on those bad boys. You need to at minimum change the pipes but it's commonly agreed that the Pcv valve on the back of the plenum should be changed and the oil cyclon ether cleaned out or replaced aswell. There are a couple of small diameter pipes at the back that will need doing aswell.
2002 4.4 cooking on gas
Ryoken
Post by Ryoken » Tue Sep 02, 2014 8:48 pm
ive ordered the 5 pipes and the cyclone valve  not got the pcv one but if that needs changing I can get that aswel
