did , my first scan on the obd2
Ryoken
Post by Ryoken » Mon Sep 01, 2014 4:20 pm
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
ABS  ->  5A/D2 - Temporary system deactivation
SRS  ->  Shadow-memory:
          06/40 - Side airbag, front right door, resistance too high
IKE  ->  BD/50 - Electronic braking-force distribution
PDC  ->  22/C6 - Acoustic generator, front, off
BMBT  ->  16/21 - EEPROM Checksum does not match with programmed value
LRA  ->  Shadow-memory:
          00/00 - Terminal 30
# SCAN END
any got any pointers ??
Steve
2002 e53 4.4  tempremental
Re: did , my first scan on the obd2
Post by X5Sport » Mon Sep 01, 2014 8:59 pm
First edit your VIN out!!
SRS:  The airbag one simply means the system is not happy about one airbag connection.  Could just be bad.  Air bag may not fire if needed in anger.
PDC:  Looks self explanatory.  Front parking sensors look to be switched off.  Had any trouble with them?
BMBT:  on board monitor head may have been changed in the past for a new/used replacement.  The system expects to see one number but it's getting another one so it doesn't recognise it.
Sanj
Post by Sanj » Mon Sep 01, 2014 9:58 pm
Mwahahahaaaa, I have his VIN!  >:D
Ryoken
Post by Ryoken » Mon Sep 01, 2014 11:53 pm
deleted everything apart from codes :)
i know the drivers door cards been removed at some point, so  that could be air bag ( window regulator maybe ?)
pdc..... doesnt work, had a rear drivers out a bit ago which got replaced, all sensors work now but, still get  flashing bdc and long beeeeep.
bmbt. could be i  updated the firmware on the sat nav , could be that?..
dunno
Steve
Post by X5Sport » Tue Sep 02, 2014 10:38 am
It's a possible with the door card and the air bag plug isn't fully home.
PDC obviously still needs investigation.  If the sensors are all clicking then it could be a module issue, or a wiring fault.
BMBT, no the software change is in the boot so that shouldn't affect the head as it's only taking a video stream from the nav computer.  It may be that at some point the head failed and was replaced?
