The comms screen on my 2003 X5 is slow to load up in this cold weather. It often takes about 5 mins of flashing before I get the BMW logo and then it loads up and everything works fine. It is worse the colder it is. Any one else have this problem? Do you think it is just the cold or might there be something wrong?
Graeme.
Comms screen slow to load up
- gmc15
x6 M50d
PhilT
Re: Comms screen slow to load up
Not noticed anything with the tv screen but the Check Control display becomes really slow when its cold
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
MaximumJed
I have this issue on my '02. It happened last winter, was fine in the summer and is now happening again. I think it is caused by the nav computer as occasionally, if it takes a really long time for the screen to appear, instead of the BMW logo and the normal screens, I get a bright blue, blocky text version of the normal screens that shows all features except navigation.
I kept promising myself that I would upgrade the nav box to a newer one but when it got better as the weather improved I forgot about it.
2002 E53 4.6iS, Black with Black interior, TV, Nav
Soon to get X-Pipe
Would like to get Paddle Shift, Glass Screen, Remap
Soon to get X-Pipe
x5south
I had a very similar problem with my sat nav screen and the blue text issues last year and a new battery once again sorted the problem.....
It seems that the battery solves lots of gremlins and with the cold being issues for you both, it might possibly point to a weak battery.... Good luck getting things sorted
StumpyPete
I've had a similar issue on my E70 which is always due to condensation on the Nav Disc. Give it a wipe and it is fine again. It seems that it is trying to read the disc but cannot, causing the computer to re-read it over and over. Might not apply on the E53 but worth a check.
Mole
hi
yeah got the same problem with my e53 about 2 weeks ago but i havent even got my sat nav back ! started it up as normal and got the same, old style block letters on the screen and no satnav. went to the boot and tried to eject the disc to see if it might fire it back up but it wouldn't even eject, but the power light is on ? any ideas much appreciated as i phoned bmw and they wanted 6 to 700 quid for a new sat nav unit !!!!!!
thanks
thanks
One trick may be to pull the fuses for the Sat Nav, wait a few minutes and put them back. Mine's not here at present so I can't tell you ones, but it could be 7 and 41 in the front box.
Easier than taking the battery off for an hour, but that's been mentioned as a trick in the past.
Mole
Thanks going to give pulling the fuses a go later tonight ! i have disconnected the power lead from the back of the unit and left it a couple of minutes but that didn't work !
- gmc15
[quote=""StumpyPete""]I've had a similar issue on my E70 which is always due to condensation on the Nav Disc. Give it a wipe and it is fine again. It seems that it is trying to read the disc but cannot, causing the computer to re-read it over and over. Might not apply on the E53 but worth a check.[/quote]
I have updated the software to v32 and got an updated dvd disc and the system loads up immediatelly now - even at -4 c this morning
Graeme.
Graeme.
x6 M50d
