Morning. ....
Went to fill up this morning at my usual petrol station and I couldn't get the nozzle in, thought I picked up the wrong fuel type but it was the right one.
Went to another station as I read on another forum that the nozzle may be damaged but had the same issue.
Any ideas?
Fuel
Re: Fuel
Could be an issue with your anti-misfuelling system on the car. BMW started fitting it across the diesels cars from 2007 onwards.
The fuel port has two latches on it which are designed to prevent the flap just at the top of the filler pipe from opening if the wrong (21mm petrol) pump is put in there. If one of the catches has jammed/locked etc then the little flap will not open. Only a diesel (24mm) delivery nozzle is wide enough to press on both latches.
Never anthropomorphise computers. They hate that.- Steamyrotter
Re: Fuel
And don't drop it!
That sort of comment really appeals to my sense of humour....
>:D >:D
And don't drop it!
>:D >:D
