gareth82
[quote=""t400""][quote=""gareth82""]Sounds the ticket mate. Can I ask a favour, could you check if it initializes the rain sensor. If I does I will order one if not I will have to go with inpa. If you could confirm this it would be greatly appreciated
Thanks[/quote]
I havent discoved the rain sensor option..yet
it might be called something bmw esque in the menus
will double check 2morrow for u[/quote]
Gentleman much appreciated
Thanks[/quote]
2001 X5 3.0d sport
- x555
[quote=""t400""][quote=""gareth82""]Hi I am looking to do this mod too. Did you buy the abover scanner or did you go down the INPA route? I dont have sat nav fitted just the old MID, does the same principle apply for enabling this and will it function as expected with the MID instead of screen.
Off topic sorry but does BMW scanner 1.40 reinitalise the rain sensor?
Thanks[/quote]
yes i used the scanner, pretty simple to be fair.
I have the MID so i'm not familiar with that set up, but im sure it will work either way
the scanner can enable lots and you can really personalise your car.
so far i have
enabled aux heating
activated the tv whilst moving
changed the blutooth name
enables selective locking
enabled comfort opening
enabled audable and visual alarm settings
and all sorts of shizz
Maybe I could set up a loan service for my scanner?
When you say you have enabled aux heating do you mean you have got it to display on the obc or that you can actually programme it to blow hot air into the cabin area? if so this sounds like a great tool.
I have a resler and navcoder which i used to activate tv in motion and sort out my bluetooth module to enable VR but it can't do much more than that where as that little gadgy sounds great
Thanks[/quote]
so far i have
enabled aux heating
- mcc05
x555, yep it does mean allowing you to blow hot air into the cabin, I am sitting here watching through the window my X5 defrost as we speak.
Rain sensor BMW call that the AIC (automatic interval control), I will have a look later today as to BMWScanner options regarding it.
X5 3.0D Custom black carbon fibre edition
t400
[quote=""t400""]
it might be called something bmw esque in the menus[quote=""mcc05""]
[quote=""mcc05""]
Rain sensor BMW call that the AIC (automatic interval control), I will have a look later today as to BMWScanner options regarding it.[/quote]
ahh yes i have seen AIC in the menus
I didnt know what it was so left it alone
ill dig deeper and post up my finds later..
As for my aux heat not working - any advice?
[quote=""t400""]
Ive enabled Aux heating and no its shows on the sat nav display
however, it doesnt seem to work....
I set the timer, the RED fan icon lights up continuosly
when the time comes, the RED fan icon just flashes...
No sounds from the webasto or fans?[/quote][/quote][/quote]
[quote=""mcc05""]
[quote=""t400""]
- dwgwyther
Hi T400
Quick one for you I have a 4.8is 2004 Facelift and was wondering if it would work on that as I see most say they are upto 2004? (Pre-facelift?), also does it do the key programming i.e. have the seats move when you unlock with diferent keys?
Darren
Darren
Soon very soon to be X5 40d
Previous - X5 2004 Le Mans Blue 4.8is
t400
as far as i can tell yes it will work on your 4.8
it works with E38/39/46/53/83/85
yes the programmable key thang works a treat
- dwgwyther
Great, thanks for that, looks like I will have to order one, more jobs for me when I get back home from the desert
So that will be;-
Thrust bush'es
Oil & filter change
Finish wiring reverse camera
Fit folding mirrors if I can ever get hold of a N/S one
and now have a play with the programming
Hope the weathers not to bad beginning of December
Darren
So that will be;-
Thrust bush'es
Oil & filter change
Darren
t400
You are more than welcome to borrow my scanner
£25 p/week
£25 p/week
gareth82
[quote=""mcc05""]
[quote=""t400""]
uote]ill dig deeper and post up my finds later...[/quote]
Thanks guys for checking this out for me, as soon as I get confirmation this works I will order one straight away
thanks
[quote=""t400""]
thanks
2001 X5 3.0d sport
- mcc05
I'd like to make some money back on my scanner too, I'll rent mine out for £25p/week also PM me anyone who would like to use it.
t400
[quote=""t400""]You are more than welcome to borrow my scanner
£25 p/week
yeah well mine comes with free postage and telephone support
£25 p/week
- mcc05
t400, did you get your partking heater to work?
If not have you tried the direct option to test that the parking heater is working, i.e. put 12v from the jump start positive to pin 1 on the parking heater?
- Waka
Sorry to labour the point but...
I've got a 2004 X5 3.0d with the aux heating menu on the sat nav screen.
As standard does that provide only heat to the engine and not to the interior?
Should I have had a remote with the car?
Does the software t400 have enable the aux heat option to heat the interior?
t400 are you nywhere near Sussex ;-p
When's the next meet?!
Ta,
W.
Ta,
W.
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
gareth82
[quote=""gareth82""][quote=""mcc05""]
[quote=""t400""]
thanks[/quote]
Did anyone get a chance to check this out yet? Wanting to order BMW scanner or INPA tonight so hopefully its here for the weekend
cheers
[quote=""t400""]
thanks[/quote]
cheers
2001 X5 3.0d sport
- x555
[quote=""mcc05""]x555, yep it does mean allowing you to blow hot air into the cabin, I am sitting here watching through the window my X5 defrost as we speak.
Thanks for the reply
in that case that does sound like a great bit of kit you have then
did you need anything else to be able to use it like software etc or did that all come with the scanner for £70 or what ever the price was.
If not i'm well impresed as i paid about £40 for my resler and navcoder and that doesn't do half as much by the sound of it
