Winter Tyre Info and Discussion Thread ( Keep related chat here please)
CondorX5
Re: Winter Tyre Info and Discussion Thread
Post by CondorX5 » Sun Oct 30, 2011 1:30 pm
kkodal, what wheels did you buy? What car were they used for before buying them, if you got them second hand?
kkodal78
Post by kkodal78 » Sun Oct 30, 2011 7:41 pm
here are the pics of the wheels... i bought these back in june and the advert was saying these were for X5. i did not think of trying them back then but the lugs match it just doesn't sit all the way to the rotor like the oem one does. :(
kkodal78
Post by kkodal78 » Sun Oct 30, 2011 7:45 pm
[quote=""mikem""]Are the stud holes in the wrong place (pcd should be 5x120) or is the centre bore the wrong size (should be 72.5) ?[/quote]
the center bore is to tight to fit.
mikem
Post by mikem » Sun Oct 30, 2011 7:50 pm
[quote=""kkodal78""][quote=""mikem""]Are the stud holes in the wrong place (pcd should be 5x120) or is the centre bore the wrong size (should be 72.5) ?[/quote]
the center bore is to tight to fit.[/quote]
They can be a bit tight sometimes, make sure there`s no spiggot rings left inside the wheels or on the hub, clean both surfaces up and just tighten the bolts to pull it on (make sure the bolts aren`t cross threaded before you do this).
kkodal78
Post by kkodal78 » Sun Oct 30, 2011 8:59 pm
thanks.. that made me feel a little bit better..i thought i was not going to be able to use them.
what style wheels are these..anyone?
stevee
Post by stevee » Sun Oct 30, 2011 9:00 pm
kkodal, I also found out to my cost that the E70 has a different hub size to every other BMW! I bought a set of 19" X6 wheels of ebay for winter tyres(they were advertised as fitting the X5), but found out that the hub size was wrong. The E70 needs a 74.1mm diameter bore (X6/E53 is 72.5mm).
I sent my wheels off to spit and polish (kent) and for £10/wheel they re-bored.
steve
X5 E70 (2011)
kkodal78
Post by kkodal78 » Sun Oct 30, 2011 9:19 pm
i will try to clean them first to see if it makes a different if not i might have to go the same route to get them re-bored. can you give me the info on the company who can do the re-bore job in case i need it?
mikem
Post by mikem » Sun Oct 30, 2011 9:23 pm
Ignore my last post, I didn't realise you had an E70!
The E70 has a larger centre bore, without machining the centres of the wheels they won't fit unless you use some special adapter spacers (and the offsets might not allow for them)
The E39 also used the bigger 74.1mm centre bore.
kkodal78
Post by kkodal78 » Sun Oct 30, 2011 9:34 pm
mine is an E53 not an E70..
mikem
Post by mikem » Sun Oct 30, 2011 9:40 pm
stevee`s post confused me.
They should fit then mate.
bonerp
Post by bonerp » Mon Oct 31, 2011 1:16 pm
finally got round to ordering the 18's from the tyremen with Wntrac 4 tyres - slightly spurned on by the weather conditions in NY at the mo...we always end up with the back end of what they have!
When do people start to fit them to their trucks?
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
Post by AW8 » Mon Oct 31, 2011 1:43 pm
Ideally when ice/snow bad winter weather forecast or when temps under frequently under 7 degrees.
Basic answer.............in the winter
Oh & IMO it is not a truck ;)
Hammy
Post by Hammy » Mon Oct 31, 2011 3:30 pm
[quote=""bonerp""]finally got round to ordering the 18's from the tyremen with Wntrac 4 tyres - slightly spurned on by the weather conditions in NY at the mo...we always end up with the back end of what they have!
When do people start to fit them to their trucks?[/quote]
Mine are on already, but I was driving on snow last week :D
gobiman
Post by gobiman » Mon Oct 31, 2011 3:48 pm
Currently 18 in London.
I reckon mid-Nov for me although if I was living in my place in Scotland it would be now.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
bonerp
Post by bonerp » Mon Oct 31, 2011 6:53 pm
[quote=""AW8""]
Oh & IMO it is not a truck ;)[/quote]
Its referred to as truck in 'our' household :P :thumbsup:
.... Or tonka :oops:
