Fitting a Westfalia Detachable Towbar & Dedicated Electric
How-To articles ONLY go here.
Re: Fitting a Westfalia Detachable Towbar & Dedicated Electric
Post by henrym3 » Thu Dec 07, 2017 4:50 pm
I'm almost embarrassed to ask, but age gives me an excuse. I followed the brilliant guide, got everything fitted, fixed a few faults along the way (exhaust, heat shields, rust.) but the smallest simplest of tasks alludes me. How to secure the tow hook inside, I know there's a Velcro strap but I am not seeing where it attaches.
VW R32 Gone
Greydog
Post by Greydog » Fri Dec 08, 2017 7:31 am
Morning Henry
Left side of the boot under the floor, it fits into a frame tail up. The tail sits in the formed plastic edge piece, mine has an over centre clip to lock it in place. I will take a pic later if it helps
Greydog
Post by Greydog » Fri Dec 08, 2017 1:04 pm
Post by henrym3 » Fri Dec 08, 2017 1:21 pm
Brilliant Greydog, I haven't got that overcenter clip, I'll have to try and acquire one. Thanks for taking the time to help, much appreciated.
VW R32 Gone
Greydog
Post by Greydog » Sat Dec 09, 2017 7:22 am
Morning Henry
Just had a look on realoem and the mounting bracket complete with over centre lock is Part 71601097191 in equipment and parts.
Some of the specialist breakers may be a starting point
Dave
Post by Alan Gunn » Sat Dec 09, 2017 8:45 am
Thanks for that Graydog.
Now i know where to put mine instead of having it floating around in the boot.
Post by henrym3 » Sun Dec 17, 2017 1:05 pm
Looked in the boot and saw this. Image the two black wires have come out. It’s not clear to me which holes they go back into. A picture or idiots guide would be great.
VW R32 Gone
Post by Alan Gunn » Sun Dec 17, 2017 1:27 pm
Both black in the first by the looks of it.
Post by X5Sport » Sun Dec 17, 2017 1:34 pm
I’d go with that...assuming black has been used for DC Ground.
Post by henrym3 » Sun Dec 17, 2017 1:53 pm
My only issue with that advice is that the hole is very small and wires very thick in comparison. One would really struggle if not impossible to fit both wires in one hole?
VW R32 Gone
Post by X5Sport » Sun Dec 17, 2017 5:12 pm
Here’s a suggestion then.
I agree that they do look a little ‘chunky’ to make fit so what you could do is strip one back a little further and solder the second wire to it a bit higher up, cover it with a bit of heat shrink sleeving and then you only have one wire’s thickness to get in the hole.  If that makes sense?
Post by henrym3 » Sun Dec 17, 2017 7:07 pm
Perfect sense, I think I had a dose of "can't see the wood for the trees"
VW R32 Gone
tsinc
Post by tsinc » Tue Jun 25, 2019 9:09 pm
I've just bought myself a new trailer and it comes with LED lights which is causing issues when using the brakes or indicators as the LEDs require much less power than conventional bulbs.
Has anyone fitted resistors to the towing electrics to stop this?
