www,bwchiptune.co.uk remaps offers for xdrivers
celica
Re: www,bwchiptune.co.uk remaps offers for xdrivers
[quote="sitrom"]
I have my car (X5 35d) booked with him for this Saturday. So I am sure he is still remapping X5s.
What was cost
Feedback on results and experience of service
What was cost
Marrow
E70lci 3.0d 245bhp figures and cost ??
- jason@bwchiptune
- Contact:
[quote="Marrow"]
I normally see 300-310 Bhp with an extra 60ft
Remap is £450 on these
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
UB3 1BB
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
UB3 1BB
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
Marrow
[quote="Marrow"]
Any dealers in the East Yorkshire area by any chance ?
- jason@bwchiptune
- Contact:
Simon thorpe in hull
01472 355520
Sent from my iPhone using Tapatalk Pro
01472 355520
02085611818
02085611818
Richardgiz
Hi Jason,
I have a 2012 X5 40d 306hp. I recently purchased a Racechip. My ultimate goal was not outright performance gain, but improved MPG and retention of drivability. I have found the Racechip does not deliver any real improvement in MPG and whilst midrange is significantly improved, the drivability at low speed is worse particularly on part throttle from a standstill. I am returning the Racechip.
Is this something you would be able to address for me with a remap and how much would you charge?
Thanks Jason
Rich
Thanks Jason
Rich
Sit
Any official installer near Bristol, also interested to know how this affects AUC warranty, can it be ‘seen’ if in for routine servicing??
Si
Si
2010 X5 30d M Sport Carbon Black | Camel Leather, 20's | HUD | Shadowline | Privacy | CIC iDrive | Adaptive Drive | Pro Nav | Loudspeaker Audio | High Beam Assist | Enhanced Bluetooth | Media Pack | Bum Warmers!
Based on what others have had happen, then yes it can. Jason may have a new trick, but earlier ones when found resulted in the code being overwritten and the warranty being torn up. That was a couple of years back though.
BMW servers know what codes exist on each car and keep a record. If something called the checksum doesn’t match then the system assumes there is an issue and rewrites the map back to the last known good one. Friendly of them! >:(
If the checksum stays intact then a map ought to be invisible......and that may be the latest trick
Sit
Hmmmm so maybe it needs to be one of those products with a 'switch' type box which allows you to return the car to the stock map if required, that way it could be returned to stock prior to service then 'remapped' afterwards??
Am I on the right lines with that thought process?
Si
Si
IanP
Being do a bit of research re X6M tuning, and while BMW might not be able to see if the car had been remapped once it has been removed, they will certainly be able to see that the the stock parameters have been exceeded i.e. boost pressure. Depends if they decide that this has affected the car if a claim is made.
As an aside, my wifes new 2 series coupe can send data to BMW without being in a garage, as I guess all new BMWs can. A remap would soon be picked up.
rneale69
I am new to this forum as came across it looking for recommendations for a good tuning company. Jason has just done my X5 4.0d and it is so much better to drive, really pleased with the result and a genuinely knowledgeable guy. I can certainly recommend him and the team at BW Chiptune.
