How-To articles ONLY go here.
jaynana
Post by jaynana » Thu Jan 17, 2013 11:24 am
[quote="X5 ALN"]
[quote="jaynana"]
INPA - stayed away so far, but now i feel like 'why not'...
where can i get a list of 'what is possible' with this software pls?
j
http://bmwcoders.com/forum/showthread.php?p=1
I downloaded it there first, trying to get a mates cable to work.
I then ended up buying my own cable that came with a disc with all the program's on it.
It's very fast. I can start it, read codes, check webasto function and close it down, before VMware loads up DIS - which means nothing to you just now lol
thanks, read a bit, seems like a minefield and a challenge! i've sent a request to register. will need lots of help A  :-[
X5 ALN
Post by X5 ALN » Thu Jan 17, 2013 7:27 pm
In response to the comments in my VIN devoder post
From my experience - coding the car for SA536 PARKING HEATER may actually prevent your webasto from working - as it may look for a changeover valve (which divides the engine/cabin water system so that only the cabin is heated).  When it doesn't find this valve - it will report a fault and cease operation.
If you get past that fault - you then may face a fault with the control panel - as there is a different one which applies to the option code SA536 - www.realoem.com you will see there is 3 different panels.
My scenario
Webasto faulty - unknown
Coded car to SA536 - webasto wouldn't start with timer
Fitted aftermarket remote receiver/transmitter to pin 1 - webasto wouldn't start with remote.
Purchased software - discovered glow plug was reporting a short circuit to ground and an IHKA fault.
Replaced glow plug - both fault codes remained
Replaced webasto ECU - glow plug fault code cleared, IHKA fault remained.  Webasto wouldn't start with timer.
Removed SA536 coding, IHKA fault cleared, webasto sprang into life.
robs530d
Post by robs530d » Mon Feb 25, 2013 3:21 pm
Hi everyone!
Well finally I sorted my problem!  :)
I finally tracked my problem down to a coding issue, my IHKA & Heater were coded wrong!
My IHKA had the 'zuheizer' coded to k_bus & my ZHZ (Zuheizer) module was coded to 'konventionell' after changing my ZHZ module to k_bus to match my IHKA module my error code dissapeared & now everything functions correctly as it should! Webasto runs, fan light on Nav surround comes on & the fans turn them selves on after a few minutes!
Woooooooooooooohoooooooooooooooooooooooooooooooooooooo
I just wanted to say a huge thanks to everyone on this forum who have such a huge great help to me!
This damn thing almost drove me to breaking point  :'( But with the help of this forum I got there in the end!!
Thanks guys!!
jaynana
Post by jaynana » Mon Feb 25, 2013 3:29 pm
excellent result, and its a chilly winter  :thumbup:
Steamyrotter
Post by Steamyrotter » Thu Feb 28, 2013 12:45 am
[quote="X5 ALN"]
NCS expert gives an option for this valve fitted or not.
May help??
Set mine both ways and no errors.
Don't think i have the valve either
Denis O
Post by Denis O » Sat Nov 30, 2013 11:16 am
Sorry to bring back the missive but I'm going to do mine before it gets too chilly. So far I've bought the remote,
http://www.maplin.co.uk/p/velleman-2-ch ... dule-a92jl
I've looked at the wiring diagram at the beginning of this thread and realise I need to buy a seperate LED. Will this one do the job.
http://www.ebay.co.uk/itm/130404711495? ... 1423.l2649
Is the wiring diagram on page 2 the correct one for my remote kit.
No doubt more questions to come as I start the job.
05 Mercedes SL350
jaynana
Post by jaynana » Sat Nov 30, 2013 2:19 pm
re. the led is it 12v rated? didn't spot that in teh advert. if not i'm not sure whether it'll get fried. i picked up a 12v rated flashing jobbie from maplins.
also if you have an intravee you prob don't need an led. intravee latest firmware has a feature where it can switch on the side lights for 2-3 long seconds when the webo is enabled... only difference is if u fix an led it will keep going while webo is on.
wiring - not sure what's in page 2 (lazy.. ) but i recommend wiring it in the boot - no water ingress or temperature issues, already fused so no extra fuse needed. OEM goes in here.
Denis O
Post by Denis O » Tue Dec 03, 2013 12:22 pm
OK. Connected pin 1 (yellow with green stripe wire) to 12v supply and immediate noise from the Webby. This noise, sounding a bit like a fan with a buzz got louder and then ran quite happily for the 4 minutes it was powered.
Checked water and a small jet was being fired across the expansion tank neck.
Once I disconnected the 12v supply the Webby continued to run. I started the car and ran it for 30 seconds and then switched off and the Webby was still running. Is this correct. I don't want to go out in a couple of hours and find I've got a lovely warn car and a flat battery.
It looks like everything is normal so just needs everything connecting and we should be good to go.
05 Mercedes SL350
jaynana
Post by jaynana » Tue Dec 03, 2013 3:49 pm
good scene, yeah sounds normal - it like a good boy does a clean up job prior to going quiet when you power down - air fan (what you hear) is the last to go off.
Caesium
Post by Caesium » Wed Dec 04, 2013 11:24 am
Is there a timer to kill the heater after a certain time?
I'd be concerned that if it malfunctioned or you forget to switch it off it could catch the car alight.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
Denis O
Post by Denis O » Wed Dec 04, 2013 12:49 pm
Thanks for your help Jay.
Caesium
The remote I bought from Maplins has the ability to be set for certain times so 30 minutes and should be good.
05 Mercedes SL350
Denis O
Post by Denis O » Fri Dec 06, 2013 10:00 am
This is a picture of the remote kit from Maplins and I need some help with wiring.
I'm pretty sure that the power input is clear and can take the + and - from the usual places under the bonnet. It appears that polarity doesn't matter unless someone tells me different. The difficulty I'm having is which terminal goes to Pin 1 on the webby and which goes to earth. I will be interupting the Pin 1 connection with the LED. Also do I use the set of 3 adjacent to the power in (CH 1) or the set of 3 further away (CH 2) or doesn't it matter. I do want to be able to have the remote set the running time for 30 minutes.
05 Mercedes SL350
jaynana
Post by jaynana » Fri Dec 06, 2013 5:48 pm
fix it in the boot mate, not under the bonnet, post [edit] 23 here... added advantages:
- ready plug with +12v already fused to take wires from
- no water ingress problems
- no visible wires under the bonnet
in terms of the wires in your diagram, pls check with the manual if its CH1 or CH2 which stays latched for 30mins or x num of minutes when you press the button. i think its CH1 form memory (i don't have this anymore cos i changed it to a GSM remote)
once you figure out whether it CH1 or CH2, re. which wires, looking at your diagram, you should connect +12v to COM and the pin1 on the webo to NO.
note that nothing in CH1 or CH2 goes to earth because what the webo needs is a +12v not a ground.
richie0270
Post by richie0270 » Wed Apr 08, 2015 5:24 am
I fitted a GSM controller from Advent Controls.
It works really simply and is activated via a txt msg so no restriction on range.
It turns on the heater via pin 1 and when it gets warm, the car turns on the interior heater and heh presto, warm car....  :)) :)) ;)
Post by X5Sport » Wed Apr 08, 2015 8:55 am
[quote="richie0270"]
But does it shut down on a 'low battery' or 'low fuel' condition?  If not you could find yourself with a flat battery/no fuel and unable to start the car.
