A lot of ppl have asked various questions about what to do if webo doesn't work on +12v to pin 1, plus i'm trying to help a few ppl on email directly as well.
so i thought of a general guide..
pre-requisites when you do the power to pin 1:
1. i think you need to have aux heating enabled with a scanner or similar on the obc (not sure if webo works without being enabled in the obc)
2. good battery voltage (i think webo is designed to not run way before car becomes unable to start due to low voltage)
3. coolant temp has to be be below 60c (so if the car has already run, nothing much extra the webo can do, so it won't start)
4. no errors logged in the aux heating module of the obc
if the webo doesn't work on +12v to pin 1, here are the options i can think of:
1. you can easily get a used webo from a breaker with warranty from fleabay..
- pros: easy, webo is like plug and play
- cons: only hope the issue is not external to teh webo. important external components are the water pump and the fuel pump
2. get a diagnostic kit (
Reslers along with
webo test sw is my choice)
- pros: you can individually test the water pump, air fan, fuel pump, full working unit, read and clear the webo fault memory, etc
- cons: assume you find an error. so what next? this is a long journey.
3. test and repair/replace the pcb and/or the glow plug. This is the Achilles' heel on the webo. my proven source is
this.
- pros: you can run the car with these components removed. at a relatively low cost you can certify the most suspicious part
- cons: not as easy as plug and play. have to dismantle the webo to remove the glow plug.
4. service the webo. instructions at teh start of this thread. glow plug failure is usually caused by muck. webo is like your boiler in teh house, except, it has never been serviced!
5. go the whole 9 yards.. like i have!
webo is a beast, not easy to diagnose! i had this exact same situation when i started (webo initially worked for about a minute, but only blew cold air from teh silencer, eventually it stopped working even when i clear the error on the obc - possibly got into a locked out state).
i spent considerable time and money to get this sorted. having done that, i can recommend the above approaches to anyone so that hopefully you can avoid.. at least a part of the nightmare
all the best
j
