when the car is started on a cold morning the webasto fuel pump can be heard to knock, knock until the car is upto full working temperature. so working properly there.
lately in parked up mode, the webasto has been firing up running for a couple of mins then shutting down.
after a bit of a play with it today ive discovered that the auxilliary remote water pump (located near main radiator expansion tank) is no longer working (no water jet visible at filler cap), thus the webasto is firing up, overheating because of no water circulation, and shutting its self down for safety.( the webasto gets VERY hot to the touch!)
obviously when the engine is running, the main water pump circulates the water through webasto so it works normally then.
im wondering if any generic 12v water pump will do as a replacement as the original part looks expensive!
