How-To articles ONLY go here.
dirtymonkey29
Post by dirtymonkey29 » Sat Jan 07, 2012 3:46 pm
Should kick it into life then. Fuses would be first place to start
jaynana
Post by jaynana » Sat Jan 07, 2012 8:30 pm
[quote=""dirtymonkey29""]Should kick it into life then. Fuses would be first place to start[/quote]
boo hoo :cry: so i'm out of luck on this one?... i've never heard the 'tick' sound like you said in the other post, on the passenger side either, when the engine is cold and outside temp is below 5c
well, i've ordered the scanner 1.4.0 anyways, lets see what joy that brings me.
dirtymonkey29
Post by dirtymonkey29 » Sat Jan 07, 2012 9:17 pm
Where you based again? I have the memory of a goldfish
jaynana
Post by jaynana » Sat Jan 07, 2012 9:22 pm
[quote=""dirtymonkey29""]Where you based again? I have the memory of a goldfish[/quote]
london mate, u in yorkshire u said? too far :cry:
dirtymonkey29
Post by dirtymonkey29 » Sat Jan 07, 2012 10:22 pm
Aye, I'll sent thy pidgeon lol
jaynana
Post by jaynana » Sun Jan 08, 2012 11:33 am
good morning mr dirty monkey (and others), i've made progress!! HURRAHH :thumbsup: re-tried giving +12v to pin 1 of webasto and HURRAAH!! it ran this time (so maybe my batt was down yesterday). and opened the coolant filler cap to check plumbing - there's a steady flow of water comin through. :)
so i guess tha's one step forward.
AND the scanner was ordered yesterday and should be on its way!
question - when i power up pin 1 as above, should the fan inside the cabin run and get the interior heated? interior fan didn't run (this is without enabling the aux heater from the computer as i don't have the scanner yet)?
dirtymonkey29
Post by dirtymonkey29 » Sun Jan 08, 2012 12:19 pm
If you let it run for 10-20 mins the interior fans come on. If your coolant is flowing it should get hot. Mine just blow cold and I don't get the coolant circulating, wish I could work out why. I get no errors and it works as it should when it's cold enough. When you've got 12v to pin one it makes no differences whether it's enabled on obc or not as your basically overriding it.
jaynana
Post by jaynana » Sun Jan 08, 2012 1:02 pm
[quote=""dirtymonkey29""]If you let it run for 10-20 mins the interior fans come on. If your coolant is flowing it should get hot. Mine just blow cold and I don't get the coolant circulating, wish I could work out why. I get no errors and it works as it should when it's cold enough. When you've got 12v to pin one it makes no differences whether it's enabled on obc or not as your basically overriding it.[/quote]
re. ur water not circulating - i've seen a plumbing diagram on one of these posts - that might be of help to you? admittedly its way to complex to my simple brain.. :headbang:
dirtymonkey29
Post by dirtymonkey29 » Sun Jan 08, 2012 1:08 pm
With my engine running I get water circulation (jet in header tank) just not when it's running the webasto alone.
jaynana
Post by jaynana » Sun Jan 08, 2012 1:16 pm
[quote=""dirtymonkey29""]With my engine running I get water circulation (jet in header tank) just not when it's running the webasto alone.[/quote]
so your condition without engine, when you power pin 1 is:
- webasto starts up (u know cos it makes a noise)
- no coolant coming in when you open the coolant filler cap
- cold air from the exhaust under the passenger seat webasto exhaust
if above is all true your webasto coolant pump is possibly not working?
dirtymonkey29
Post by dirtymonkey29 » Sun Jan 08, 2012 1:58 pm
Which is located where? Thermotop z doesn't have one and uses the car water pump to circulate water which works normally when the engine is running as does the webasto when car is running and temperatures are below the threshold. The thermotop c has an additional water pump attached to the front of the heater as per pdfs I posted up earlier.doesnt help that the unit is labelled up as a thermotop z on the front and thermotop c on the side.
jaynana
Post by jaynana » Sun Jan 08, 2012 2:44 pm
[quote=""dirtymonkey29""]Post 327 has a repair manual and parts list in one of the PDFs[/quote]
this set of pdfs? how do i load post 327? sorry mate new to this forum. i don't know how to upload photos another thing..
Johnny chimpo
Post by Johnny chimpo » Sun Jan 08, 2012 7:11 pm
Just thought I would post up to say that mine is all working okay. All I needed to do was enable aux heating using BMW scanner. Tested it this afternoon and after 10mins it was still running and putting nice hot air onto the windscreen. Actually really chuffed as I did t expect it work.
Current Fleet:
2005 X5 3.0d Sport......... Now Sold!
2011 Passat Bluemotion
2009 MNR Vortx.... 12k screamer!!!
2012 C220 AMG Sport
jaynana
Post by jaynana » Mon Jan 09, 2012 8:28 am
[quote=""jaynana""][quote=""dirtymonkey29""]Post 327 has a repair manual and parts list in one of the PDFs[/quote]
this set of pdfs? how do i load post 327? sorry mate new to this forum. i don't know how to upload photos another thing..[/quote]
hey mr monkey which pdfs mate? btw, below is the unit i have, is this what's refereed to as Thermo Top C? (Z on the front, C on the side).
dirtymonkey29
Post by dirtymonkey29 » Mon Jan 09, 2012 4:59 pm
I'm wondering if my water valve is knackered. Item no 4 below
http://realoem.com/bmw/showparts.do?mod ... g=64&fg=18
Thing is it works normally when temps are below the threshold. When running 12v direct to pin 1 the heater starts up but I don't get any coolant flow in the header tank
