Page 21 of 45
Re: Moving On
Posted: Fri Feb 06, 2015 10:36 pm
by Sanj
Well done Imy for negotiating an excellent deal buddy - did you pull the trigger and get one for yourself in the end?
Jig - well done on getting the deal you wanted man. Should help with the money saving grand plan. Btw, got a few quid spare - glass shower screen are f**king expensive!!!!!
Re: Moving On
Posted: Fri Feb 06, 2015 10:45 pm
by jeegnesh
[quote="jeegnesh"]
So i found some docs, I have Chargemaster Homecharge Type 2 30amp unit, looks like.
So I take it I need the Type 2 to Type 1 lead, there a 16amp and 32amp version, which one would I need?
30A = 6.6kW so you can fast charge yours.
Don't think so as I have the 3.3k unit in the car.
Re: Moving On
Posted: Sat Feb 07, 2015 7:58 am
by Don Coffey
[quote="jeegnesh"]
[quote="Don Coffey"]
Go to zap-map.com there is a seller of charging cables on there. You will need to confirm what type plug is required to fit the wall socket. Hopefully it's a type 2. The leaf is a type one.
Is it a two year PCP deal?
Don
Yes 2 year PCP 0%
So i found some docs, I have Chargemaster Homecharge Type 2 30amp unit, looks like:-
Type 2'to type 1 is the standard set up for Leaf. Although you need to purchase the cable it will be the same one for fast chargers. Go with the 32amp as it will future proof you if you do get another leaf as its expected to have the 6.6kw as standard on the next model.
Don
Re: Moving On
Posted: Sat Feb 07, 2015 7:59 am
by Don Coffey
Can I have the name of the dealer and salesman? PM if you wish.
Don
Re: Moving On
Posted: Sat Feb 07, 2015 9:33 am
by jeegnesh
So public points I would need that cable, and they don't supply that, terrible.
Don I'm gonna leave Imy to disclose details, it was his deal and he's thinking about ordering so once he does his he will disclose
Re: Moving On
Posted: Sat Feb 07, 2015 11:02 am
by 535dboy
I don't expect to use public points but do none have a cable?
Re: Moving On
by 535dboy
Insurance done
£250 with no NCD
Re: Moving On
Posted: Sat Feb 07, 2015 12:25 pm
[quote="535dboy"]
None that I have ever seen in any of the motorway services or in Milton Keynes. Do all the manufacturers use a standard plug on the car end?
Re: Moving On
Posted: Sat Feb 07, 2015 12:31 pm
by 535dboy
[quote="535dboy"]
Dunno !!
Bit like you are oracle for X5s, Don is the oracle for all things leafy!!
Re: Moving On
Posted: Sat Feb 07, 2015 12:43 pm
It appears there are two types - called a Type 1 and Type 2. They are different and the Type 1 is falling out of favour although that is what the Leaf comes with (you may get a T1 - T2 converter). If I'm reading things correctly you could have a T1 and T2 connector on board depending upon what options you chose when ordering. Some charge points have a T1 or T2 cable but many don't.
At a guess you may have to buy and carry both types!
Re: Moving On
Posted: Sat Feb 07, 2015 12:45 pm
by 535dboy
Or never drive further than 35 miles away from your house !!
Re: Moving On
Posted: Sat Feb 07, 2015 12:46 pm
Hmm. Sounds like the old VHS/Betamax, BluRay/HD-DVD arguments all over again. >:(
Re: Moving On
Posted: Sat Feb 07, 2015 4:03 pm
by jeegnesh
So most common currently is type 2 to type 1 also known as public charging cable that's the one you will most likely need. Yes you can get converters too
Re: Moving On
Posted: Sat Feb 07, 2015 6:17 pm
by Don Coffey
To confirm, type I is the plug on tje leaf, the type II is the plug that fits a 7kw fast charger. These are the ones that take 4-8 hours to charge depending on whether or not you have a 3.3kw or 6.6kw charger. These machines do not have a tethered cable so you have to carry one if you wish to avail of these. The 50kw Rapid Chargers will give 80% charge in 30 minutes and these do have a tethered cable so no need for carry one for these machines.
Don
Re: Moving On
Posted: Sat Feb 07, 2015 6:49 pm
by shadrack
Don
50kw chargers.....half the streets lights will be out when you plug in!
