Flickering aftermarket LED brake lights with error on dash
Dimsum
Re: Flickering aftermarket LED brake lights with error on dash
Post by Dimsum » Thu Oct 26, 2017 12:02 am
Anyone?
Post by X5Sport » Thu Oct 26, 2017 6:14 pm
You need to put a Canbus cancellation part in there.  LEDs have a far lower resistance than bulbs and the system thinks there is a fault.
LED lights also illuminate far faster than filament so you are seeing the cold lamp check that is normally invisible with conventional bulbs.
You can code out the cold lamp check but will need Canbus cancellers to clear the error code.
Dimsum
Post by Dimsum » Thu Oct 26, 2017 7:54 pm
Thanks X5Sport. Ideally I was after the pics that were originally in the thread to point me in th right direction. :D
dark_stranger
Post by dark_stranger » Sun Nov 12, 2017 5:20 pm
Watching as also have the same issue.
Post by Horizon » Sun Nov 12, 2017 5:44 pm
I had to code out my LED front side light hot and cold bulb checks on my X3 , used Carly app,  it BMW Scanner 1.4.0 will also do the job.
My HIDS were canbus friendly but still flashed on initial startup , didn't bother coding it out on the X3 as no error warning light.
Also on my E93 I have LED front marker angel eyes, these are canbus friendly, but didn't flay a bulb out warning when the LED burnt out, as the inbuilt load resistor fooled the canbus system that all was OK.
