High Speed Braking Vibration - Warped Discs?
dirtymonkey29
Post by dirtymonkey29 » Thu Nov 17, 2011 9:18 pm
£60 p/hr is about right for my Indy too but my general garage who has an X5 and know his stuff is £35 an hour
StewieG
Re: High Speed Braking Vibration - Warped Discs?
Post by StewieG » Thu Nov 17, 2011 10:10 pm
ok, will check out BMmoters in Bexley as recommended.
55 E53 3.0d with Pano roof and full coms pack. Black with Black
storminmike
Post by storminmike » Fri Nov 18, 2011 8:58 pm
Here's an off the wall one
I had very similar problems to this some while back,,,sort of just crept up then bang wobble wobble until a reasonable speed
The disc surface looked odd and I was getting an unswept line appearing.Bit the bullet and swapped both discs and pads from pagids from ECP,,,,no wobble anymore
now was it a warped disc or jamming pads,,,who knows. Corrosion was evident on the face and the pad was not worn flat
Meticulous (and mean meticulous) cleaning of the brake parts including the slider bit may have put the problem right...but I'll never know...but the problem went for around £120 ish. Would a parts clean of the brakes on their own put it right if the discs not obviously looking wrong.....dunno....tis but elbow grease
