Auxilary fan Pusher Fan ?64546921381 Auxilary fan X5 e53 3.0i
hawkar
Re: Auxilary fan Pusher Fan ?64546921381 Auxilary fan X5 e53 3.0i
Post by hawkar » Wed May 30, 2018 12:34 am
I will replace the fan and hope it will work
Post by henrym3 » Wed May 30, 2018 8:05 pm
Thanks for that, when you've had it changed let me know how much you want for it and obviously postage cost. You can put it on here or PM me. From my point of view I'd like to have a crack at getting it to spin again.
VW R32 Gone
hawkar
Post by hawkar » Fri Jul 13, 2018 8:01 pm
Hi all,
Just for the record
I have now replaced the auxiliary  fan too and it spinns finaly
the AC is very cool  :)
The engine temperature does not raise anymore as before if it does i will definately ask you guys for help again :camera:
henrym3 You can have the fan for free
Thanks for all the help
Colin
Post by Colin » Fri Jul 13, 2018 10:44 pm
Thanks for the update hawkar    great all is well
05 , 30d Le Mans Blue Sport
Post by henrym3 » Mon Jul 30, 2018 10:05 pm
Got the fan of Hawker, pulled it to bits and have had absolutely no success at getting it to spin. So remembered X5-D-Sports comment about maybe trying to fit an electric fan in there. As I’ve had one laying around for years I thought I’de have a go. Using the original mounting bracket for the motor it was easy to mod to hold the new fan motor.Image
This mounting then fits straight on to the plastic frame,
VW R32 Gone
Post by henrym3 » Mon Jul 30, 2018 10:10 pm
Should have put more picsImageImage
The plastic stone guard still fits on, the fan is obviously smaller than origional but it’s all I had. Now would need to find a means of switching it on/off but it could be set to run at low speed if a/c is on and then a temperature swItch for high speed.
VW R32 Gone
