Page 3 of 11
Re: E70 quality enhancement front driveshaft ‘recall’ 2012-2014
Posted: Fri Dec 01, 2017 3:57 pm
by dgm
My car has been examined now, no movement, no rust so not replaced.
Posted: Fri Dec 01, 2017 4:08 pm
by neo61uk
[quote="dgm"]
Shame on them!!
Posted: Fri Dec 01, 2017 6:32 pm
by DavetheBlade
Thanks for the update Neo and good luck with the fitting of the new prop shaft, be interested to see what sort if nick the old one is in and how easy/hard the replacement is to fit.
Posted: Fri Dec 01, 2017 9:44 pm
by neo61uk
Job done
Posted: Fri Dec 01, 2017 10:27 pm
by Horizon
Great write up
Posted: Fri Dec 01, 2017 10:43 pm
by neo61uk
[quote="Horizon"]
Great write up
Posted: Sat Dec 02, 2017 9:08 am
by CondorX5
[quote="Horizon"]
Great write up
Posted: Sat Dec 02, 2017 9:13 am
by neo61uk
[quote="CondorX5"]
[quote="Horizon"]
Great write up
Posted: Sat Dec 02, 2017 9:36 am
by DavetheBlade
Great write up Neo, thank you. I think I'm going to check which shaft I have, old or new before possible following in your footsteps.
Quick couple of Q's if you don't mind as you are now our resident prop shaft expert
1) what were the torque specs of the bolts?
2) Did you need to grease the shaft and if so what did you use?
Posted: Sat Dec 02, 2017 9:44 am
by neo61uk
[quote="DavetheBlade"]
Posted: Sat Dec 02, 2017 10:30 am
by snrbrtsn
That is simply an amazing post re your replacement of drive shaft.
Prior to ownership, I had doubts, so opted for the AUC purchase, however since ownership I’ve been sceptical of the shaft issue,
Your post has given me the resolve and piece of mind, Many thanks......
I’ll be in touch with with Des Shelly shafts, order a replacement and replacement bolts from Cotswold...
Many thanks for posting, I’ll follow your lead p!
Posted: Sat Dec 02, 2017 10:38 am
by neo61uk
[quote="snrbrtsn"]
Thanks mate
If there is anyone near Bristol and need help doing it, I don't mind helping out in my garage.
Got all the tools and space to do it.
All you need is a shaft and some bolts.
I'm glad I could help out.
Posted: Sat Dec 02, 2017 10:54 am
by Glen
Your a whizz with a spanner mate just PM me next time your near Durham
Posted: Sat Dec 02, 2017 11:00 am
by neo61uk
[quote="Glen"]
Will do mate
Posted: Sat Dec 02, 2017 11:06 am
by DavetheBlade
Thanks for the extra info, greatly appreciated.
