Page 3 of 3
Re: Non run-flat tyres
Posted: Mon Mar 28, 2016 9:36 pm
by adricky
Ok so I'm gonna go for non run flats, can someone recommend some good mid-range tyres please?
Posted: Tue Mar 29, 2016 5:34 am
by BullyB
[quote="adricky"]
I have Michelin Latitude Sport 3's on order.
Not used them myself yet but loads of good reviews if you google
Posted: Tue Mar 29, 2016 1:35 pm
by Nine468
Ive had the Toyo,s 20",s on my E70 for a good 2 years and found them good.
Just looking at replacing them and they are almost half the price of the Michelin option, so i might just get another set...
Are the Michelin,s twice as good.???
Posted: Thu Mar 31, 2016 12:06 am
by Pinewood
[quote="99ron"]
I 2nd that. On the 3rd set of non run-flats here on a 150K miles X5. No issues so far.
I always change all four together with same brand as the fronts aren't that far behind the rears for wear.
If the transmission goes then it will get fixed then sold as I can't live with this thing on runflats in the UK.
The * rating is a con. I ran a E60 M Sport for 5 years without a hiccup on non run flats and intend to run this X3 (once the Pirelli rft's wear out) on something similar. Midrange tyres will be lower in cost and I have no issue in changing them as a set of 4,once a axle gets down to 5mm. I often find the shoulders wear first and end up giving the dreaded slow speed rumble anyway.
Posted: Thu Mar 31, 2016 5:14 pm
Your E60 didn't have Xdrive. It's the 4x4 cars that it needs care with. Plenty of members on here now changing different/transfer boxes because of this problem. It isn't a con.
Posted: Fri Apr 08, 2016 9:08 pm
by stevee
Just fitted Michelin Latitude Sport 3s on my 20". Fantastic. Nice and supple compared to the run flats. £820 from blackcircle fitted.
I've run non RF winters for 4+ years with no issues.
Posted: Fri Apr 08, 2016 9:33 pm
by Pinewood
Ok so perhaps not a con, but i fail to see how 4 brand new (same make) non run-flats can mess up the transfer box, over 4 runflats. If people don't pay attention to wear rates on the same axis, or front to back then fair enough.
* rating surely means they meet a desired radius, but a normal tyre from the big manufacturers will also meet these basicr requirements?
I look at the North American owners on another forum, and they modify their X cars far more than us with spacers, 21" wheels etx and suffer no such issues. I wonder are we in the UK just too PC?
Posted: Fri Apr 08, 2016 9:52 pm
The only 'common' thread that has appeared is either wide tread depth variation or fitting something more 'agricultural' in it's tread pattern. Plenty of folks haven't had a problem, but a growing number are, and tyres seem to be the reason though there could and will be other reasons.
Quite why BMW fitted a system with this little tolerance seems odd for a premium brand, more so given their knowledge gained from LandRover? I agree that it should not be necessary for anyone to be limited to specially marked tyres, but BMW aren't alone in that.
Posted: Fri Apr 08, 2016 10:05 pm
by Pinewood
It's hard to know which way to go on this issue, I literally sit on the fence with tyre choice. The various members that have voiced an opinion (either way) on this thread is testament to that
Posted: Fri Apr 08, 2016 10:08 pm
It's probably one like the gearbox fluid change......do I or don't I? And that one has run and run too.
It is the best thing about this Forum. It doesn't make decisions any easier though. :cry1: ???
Posted: Fri Apr 08, 2016 10:35 pm
by celica
I'm on non star and non run flat
Currently have uniroyal rainsport up front
I do like wish they had them in 315 35 20 for the rears as rate these tyres
Posted: Sat Apr 09, 2016 8:09 am
by Pinewood
How long (miles) have you been running normal tyres?
Posted: Sun Jul 03, 2016 4:57 pm
by squeaky2
Sorry to resurrect this. I am just about to get a set of 20" refurbed to go back on the car when the winters come off
Have been looking around and at the moment there seems to be little price difference between the price of dunlop runflats and non runflats. I am however having to get one of the rears repaired again as it has a hairline crack in it.
I am only thinking about non runflats as living in london with all the pot holes and speed bumps and another driver with no mechanical sympathy at all they might be a better option. Im not so worried about the transfer box problems at the moment as we are only doing about 6000 miles a year. The ride doesnt seem to be so much of an issue either as the adaptive ride really helps.
How are people getting on with non runflats and are there any real reasons for not doing it.
Also would a mid priced tyre be that bad an option?
Posted: Sun Jul 03, 2016 7:26 pm
by Pete
You'll struggle to permanently repair a wheel that has been cracked. The Ronal wheels (I'm presuming it is a ronal) are woeful, when I used to deal with them there were so many cracked, mainly 20", wheels. BMW should have been accountable for them. The runflats certainly don't help though (mixed with our awful roads).
