transfer box chain
jagr
Re: transfer box chain
[quote="davey"]
got tyres, a slight reduction in clunks but still there, had difs oil levels checked, all ok, and checked prop shafts for wear on u/js, front shaft has some wear, back seems ok, ho hum, !!!, :(davey
What brand tyres?
Have you checked the tyre pressures yourself?
What brand tyres?
2011 BMW X3 30d M Sport
- kkx5
[quote="davey"]
What software used to calibrate transfer box? Who did it? Have You seen them doing it? All bearings were gone on yours, main shaft broken :hypo:, chain very badly stretch...
davey
bmw in york did it, main dealer,said all was well, i have little bit play in the front prop u/j nearest the trans box,
- kkx5
So we can rule out bad calibration, is it not brakes clunking? Could be play in prop....
jagr
[quote="kkx5"]
Could still be tyres as we don't know if he fitted 'star' marked tyres.....
- Gaff
Ok, butting in here, what are the right size staggered tyres I should be putting on the 19'' wheels?
Current:
E83 X3
E90 MSport
'56 LeMans Exclusive Edition X5
Honda Civic 1.6
Previous:
Toyota Previa 2.0 D4D
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
jagr
[quote="Gaff"]
235 / 45 / 19 Front
255 / 40 / 19 Rear
The only 'star' marked tyres I found when looking were Pirelli PZero Rosso for original fitment. They do the front and back.
Michelin also do the rears as 'star' marked but not fronts....they Michelin Pilot Sport2.
235 / 45 / 19 Front
255 / 40 / 19 Rear
davey
ok, here goes, went to our local tyre place, had the front tyres measured, and the back changed, same make new tyres, noise gone in all circumstances but an occasional clunk at low speed in traffic, this i can live with, but i,m confused, will change the front prop soon, and change the auto box oil and filter, but a result i think ???. davey
- Gaff
Dearest Gurus, So I have now shipped my X3 also to Trinidad, where the roads aren't without it's faults
I have been thinking to steer away from the run flats I got to normal tyres, and increase too 50 in front and 45 to the rear. Would that be an issue? keeping the ratio the same but increasing the profile. Thanks.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
The critical bit will get to maintain the rolling diameter across all four wheels. If you get that wrong the differentials will fail due to over stressing - and possibly the gearbox/transfer box. Your speedo etc will also be out. The correct size options are on the tyre pressure labels normally on the B-pillar, driver's side.
Move away from those sizes with caution.
