bmw scanner v 1.4.0
Graham_The_Baker
Re: bmw scanner v 1.4.0
Post by Graham_The_Baker » Sat Dec 18, 2010 7:21 pm
Ask him if he wants to sell it :x
sturach
Post by sturach » Sun Dec 19, 2010 4:51 pm
Thanks to graham the baker
the scanner appears to work! through his computer
However i don't seem to be able to get the scanner visible onto my usb in device manager it can't find the driver
Grahams comp was vista and mine is windows 7
have any of you got it working on win 7 and if so can you help me out
regards
stuart
Graham_The_Baker
Post by Graham_The_Baker » Sun Dec 19, 2010 9:31 pm
Nice to meet you today Stu. Is your bluetooth working ok.
Don't forget to set your Aux Heater for in the morning!
Graham
sturach
Post by sturach » Sun Dec 19, 2010 10:21 pm
Hi graham
same to you mate
I think your wheels really set the x5 off (joke)
Bluetooth works fine thanks
TV doesn't and it doesn't auto lock maybe we didn't write those over correctly
the alarm chirps now thanks
I've been trying to get mine working but not as yet a tleast we've proved the scanner is ok it's just the driver setup
I've also tried on my dads vista but can't get that working i'll have another go at his over the next few days as i'm off now till the new year
it must be something simple just a bit of a nightmare
Maybe we could meet up again when you've got time to have another go at it
regards
stuart
Graham_The_Baker
Post by Graham_The_Baker » Mon Dec 20, 2010 8:56 am
Wheels look pants but looking outside today I think I'll be having the last laugh!! LOL
sturach
Post by sturach » Mon Dec 20, 2010 11:41 am
Hi Graham
tv started working today
the settings must of been delayed because of the cold lol
what was the other thing you showed me that had a usb with wires on reseler or something i think you said
can that do the same as the scanner??
i wonder if it's easier if i get one of them because of the hassel with the drivers
all the best for xmas
stuart
Post by X5Sport » Mon Dec 20, 2010 2:17 pm
In Winows 7 there is an option that enables it to run older versions of software designed for XP as an example. Try turning it on if you have not already.
Microsoft instructions here:
http://windows.microsoft.com/en-US/wind ... of-Windows
If you are feeling really brave and are IT literate you can also run a 'Virtual XP' build inside Windows 7. A virtual system is very useful and most of the server systems we now install run these what are called 'virtual instances' where we use an overarching OS with other applications or OS versions running inside them instead of having to build a server for each version. More info here for doing it on a PC.
http://www.microsoft.com/windows/virtua ... nload.aspx
Graham_The_Baker
Post by Graham_The_Baker » Mon Dec 20, 2010 6:29 pm
[quote=""sturach""]Hi Graham
stuart[/quote]
Funny I was thinking today it said when I was doing it it needed to reset to take affect. Cool, pleased it works.
Do a search for Rolf Resler on here and the net. You will need to download Navcoder also.
Did you try out your Aux Heater??
Graham
x555
Post by x555 » Mon Dec 20, 2010 6:33 pm
stuart[/quote]
The resler will only do a few tasks and is no where as good as the scanner you have.However the scanner afaik doesn't code VR where as the resler does ;)
I had a play with your type scanner today thanks to a very generous/helpfull forum member (you know who you are thankyou)and will defo be getting one in the near future it's a cracking bit of kit...........if you can get it working of course ;)
sturach
Post by sturach » Mon Dec 20, 2010 8:07 pm
Hi Graham
aux heating working perfectly thanks
only the auto lock but that one was the least inportant
Still can't get the scanner in device manager (it's still an unknown device)
I've tried everything
i think it will be a simple adjustment when i do find it (it's one of my new years resolution to get it working before 2020)
I'm waiting for a reply off the seller regarding this matter maybe he can clear it up
have you got dvd to the front screen I've got dvd/monitors in the headrests i was wondering if you can aux out into the front screen
stuart
Graham_The_Baker
Post by Graham_The_Baker » Mon Dec 20, 2010 8:32 pm
yeh should have showed you mine. I've got a PS3 which works on front and back. Also the TV works on the rear screens.
Graham
sturach
Post by sturach » Wed Dec 22, 2010 10:08 pm
Hi X5sport
tried all you said
i think the problem is:
when i plug the usb lead in it doesn't say add hardware it just makes a noise as if you connect a usb device
If i then go to device manager it's under other devices with a ! in a yellow box next to it
you can then right click and update driver which i do but then says can't find driver even though i've picked the folder to look in
I'm sure it's something simple but can't get my head round it
I've tried different software from another member and still the same
My scanner worked on his computer (vista)
any ideas
fenj66
Post by fenj66 » Wed Dec 22, 2010 10:30 pm
as my previous post on this topic, my old laptop runs windows xp and set itself up seamlessly..might be worth a try..
sturach
Post by sturach » Thu Dec 23, 2010 9:00 am
yes this is one thing i havn't tried yet
I'll have to borrow a laptop with xp at least i can then rule out software, scanner, usb lead
i spoke to a different seller on ebay who also has a scanner for sale and he only recommends XP
so fingers crossed it's win 7 thats the problem
regards
x555
Post by x555 » Thu Dec 23, 2010 2:40 pm
[quote=""sturach""]Hi X5sport
If i then go to device manager it's under other devices with a ! in a yellow box next to it[/quote]
When you plug in the usb does the noise beep twice or three times ? I ask as in my limited/average capabilites on the pc (and i hope i'm not teaching you to suck eggs here btw :oops: ) i have had trouble in the past connecting up the resler and such things with having to download vista files (my pc is xp ;) )
I found that when i got three beeps that it would recognize the scanner/item connected but then wouldn't recognize the drivers no matter where i searched etc
and every time i re connected to the same usb port i got three beeps/bongs.
What i'm trying to say (if my ramblings are making any sense here :rofl: ) is go into hardware then device manager and remove the device then when you re connect it to the same usb port next time you should only get two beeps/bongs and then the found new hardware wizard flashes up and try again from there.
HTH in some way as it seemed to work for me :thumbsup:
