Auto Folding Mirror Fix
- Busapower
Re: Auto Folding Mirror Fix
Thanks for your reply, kind of thought that but always better to ask. Has anybody used the above suppiers that are on this thread that might have a part number for the switch and who they phoned to get it.
Thanks.
Thanks.
nujon
I've used Radio Spares (RS) for electronic/electrical bits for various purposes over the years - always found them OK - they would be my starting point
Gurbinder
would this solution also cure the clicking i get when the drivers mirror folds in and trys to bounce back out.
thanks
thanks
03 53 M3 CSL SG 10.5K
03 53 4.6IS BLK/BLK
12 12 Pathfinder 2.5 DCI Tekna
03 53 4.6IS BLK/BLK
mrb0011
Hi Gurbinder
Your problem sounds similar to mine which I believe is related to worn cogs in the motor assembly.
Does anyone know whether these cogs or the motor can be sourced separately?
Any suggestions would be gratefully received.
Michael.
Michael.
2004 54 X5 3.0D, E39 M5
Decided to look at mine today - found it easier to pull covers off applying pressure around edges & not just to side.
Metal cam/spring on rear of the Burgess microswitch was completely off & nearly swallowed into near the nylon hinge pivot on offside
Used tweezers to remove it. I had to try to reform it using heat via gas hob so as less brittle.....then refitted to the switch being careful not to shear tiny plastic tabs.
I saw on xoutpost someone worked out which part these were- hence my "Burgess" reference. The switches on car have wires going right into same so if sourced these would probably need to be fitted by cutting wires, soldering &/or or using watertight connection blocks
I couldn't take pics due to lack of readily available charged equipment - Sorry.
HTH someone. Thanks to Sanj for this original How- To
- pvr
So did it work?
Yes - working
Have emailed various u.k. stockists of Burgess switches to see if they will sell to me direct.......so I & or other members can source& keep spares.
Not hopeful of a positive reply but it would be good to find a stockist for these switches........Will update here if I can find a helpful supplier.
Ansamoiz
I am having difficulty in removing the cover. Is there only one clip on the side? Which way should I push the cover?
- PhilUK
Any news on finding a supplier for these micro-switches anyone?
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
- UrbanFlow
Phil UK,
I've just ordered a new motor, gears and metal internal cover for my mirror from this company in Taiwan. They also sell the micro switches:
http://www.hongmei.com.tw/?fits-to-bmw-outside-mirror-parts,17,3
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
- LincsX5
I've looked at the same site before, but that was as far as I got. My ns mirror is a bit loose and will move back a bit when I have towing mirrors on. I will be very interested in seeing how you get on. Sounds like an excellent opportunity for a How-To
2008 E70 3.0D SE Dynamic kit
2006 SAAB 9-3 Aero
2002 E46 318Ti SOLD
1972 Triumph Spitfire
2006 SAAB 9-3 Aero
2002 E46 318Ti SOLD
- PhilUK
[quote="UrbanFlow"]
Phil UK,
Thanks. Just sent them an enquiry.
Phil UK,
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
X5LeMans
Is wear in the switch likely to cause the mirror to power all the way in until it actually hits the door, or is there an adjustment for that. My mirrors work, but the passenger site either needs adjustment or repair I assume. (At the moment, the solution is not to use them. But they are handy when trying parking on the street.)
X MAN
[quote="UrbanFlow"]
Phil UK,
Found this european supplier selling X5 E53 mirror repair kits on Ebay.
http://www.ebay.co.uk/itm/261159885740? ... 26_rdc%3D1
Phil UK,
05 X5 3.0d
Mods:H/s wheel.F/mirrors.Lumbar.Compass-remote r/v mirror.Rem ctrl.Bins holder.T90 Telestart.20"168's.Arches.Titan grills.Skid plate. P/O load floor.R/seat e/b/rest.R/blinds.H/rear seats.is r/bumper trim.chrome dials.car key mem.intravee.DSP.RV Cam.Dbl glazing.Ski bag,Rear blower
- MarkW
When I try to fold my mirrors, the drivers one folds in and immediately out again, the passenger side just makes an awful noise and doesn't actually move. I noticed when cleaning the car the passenger side moves slightly, feels a little loose. Could both problems be switch related?
X5 3.0D Sport, Estoril Blue, Black Nappa leather, Sat Nav, Bluetooth, Pan Roof, Rear Screens, TV.
