My 1st x5, what have i done!!!!. There is so many faults with this car
storminmike
Re: My 1st x5, what have i done!!!!. There is so many faults with this car
Post by storminmike » Thu Dec 12, 2013 7:30 pm
[quote="Nat"]
Hi,
Regarding back lights, this was a known issue and BMW replaced them under warranty. Its well known and documented issue back in the day.
Repair is  to replace them .
Regards,
Nat.
Bit extreme when sandpaper might sort it  :o
Sanj
Post by Sanj » Thu Dec 12, 2013 8:59 pm
To extent for sure, clean the connectors to the bulb holders, solder joints if you should have to (shouldn't) and you should be done. Next...
Johnny-p
Post by Johnny-p » Thu Dec 12, 2013 9:08 pm
+2
Had my rear left fail on me at the weekend..
Took the cluster out and low and behold there was corrosion on one of the contact points,bit of wet n dry and all good again  :xmasgrin:
Don't get too despondent fella..
I bought mine with LOTS of hidden faults and touch wood I'm at the end-for the moment!!
When it is running good it's all worth it,even if it's only just for the driving view 8)
2005 X5 3.0d Sport-Black sapphire-cream leather-pan roof-folding mirrors-sliding boot floor-soft close tailgate-heated F/R seats-F+R air con-rear blinds-Bluetooth/voice recognition-satnav/tv in-motion-aux enabled-headrest monitors/DVD-aux heating-alarm chirp-chrome dials-detachable towbar  ;)
storminmike
Post by storminmike » Thu Dec 12, 2013 9:42 pm
[quote="Sanj"]
when my nearside was so pitted that the springyness of the holder wouldn't suffice I had to resort to filling in the pit with solder. It was a little pit but deep enough to make a poor (to the computer) connection
Loadsa flux...blob of solder (hard to heat) and bob's you auntie after a sand......been that way for 2 years now
storminmike
Post by storminmike » Thu Dec 12, 2013 9:44 pm
[quote="Johnny-p"]
+2
He didn't mention webasto....quick....have it away :))
Johnny-p
Post by Johnny-p » Thu Dec 12, 2013 10:18 pm
No he didn't  so Ssssshh  it might hear you :blink:
Steamyrotter
Post by Steamyrotter » Thu Dec 12, 2013 11:13 pm
or gearbox.............. :o
andy406
Post by andy406 » Fri Dec 13, 2013 5:32 pm
is it a hard job to remove the back brake lights
Johnny-p
Post by Johnny-p » Fri Dec 13, 2013 5:59 pm
Easy peasy just 3 bolts to undo.
Remember to put a rag down the hole to stop any bolts getting lost ;)
Steamyrotter
Post by Steamyrotter » Fri Dec 13, 2013 10:27 pm
and don't rush it as you'll cut you hand to shreds...
nujon
Post by nujon » Sat Dec 14, 2013 12:46 pm
"Noise from behind heater control when car is turned off" - does this stop if you wait a while?
If not:-
1. check if it is the blower running at low speed (this can be caused by the final stage resistor which you say you have replaced - with new?) - to do this, pull the 50 amp blower fuse - if the noise stops, leave the fuse out for now to save your battery and go to 2. below - if not, then its something else
2. the blower may be running with the ignition off due to incompatible coding of the IHKA unit typically caused by someone having tried, by the wrong technique, to enable park heating on a UK 3.0D - to check this, look and see if "aux heating" appears on the MID/OBD - if so, remove the option with a scanner and re-start the IHKA unit software
3. pull the IHKA 7.5 and 10 amp fuses , lock the car and wait for it to go to sleep (if it does, then that suggests that IHKA coding was the indeed the issue). Leave the car for a couple of hours, then re-install the fuses and check if all is well.
