To block pave or Tarmac?
General off-topic chat.
Re: To block pave or Tarmac?
Post by X5Sport » Wed Oct 02, 2013 9:09 pm
[quote="Nat"]
Hi,
Thats some driveway , 700m2.......................
With his other toy being a 'fling wing' his drive is better known as a helipad....... 8)
pvr
Post by pvr » Wed Oct 02, 2013 9:36 pm
[quote="pvr"]
You might still get some surface weed if you don't drive over it enough (you can just hose it away though).
So it doesn't keep 535dboy out then eh?  Although I suppose the 'hose method' might sort that bit......  :P
When he has been, I still have to hose the drive when his cars lose their oil again  >:D
pvr
... or where he has been incontinent again ...  :blink:
snipez999
Post by snipez999 » Wed Oct 02, 2013 9:39 pm
Always Uniform Diarrhoea Interests ?
sid10
Post by sid10 » Wed Oct 02, 2013 9:41 pm
Hi block pave , you can get a cheap 5 gallon drum of chemical they use for washing out milking parlours , dilute & pour on drive with watering can twice a year , stops weeds & moss !
pvr
Post by pvr » Wed Oct 02, 2013 9:43 pm
[quote="snipez999"]
Lots Of Trouble Usually Serious ...
535dboy
Post by 535dboy » Wed Oct 02, 2013 9:44 pm
[quote="snipez999"]
That doesn't even make sense!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
535dboy
Post by 535dboy » Wed Oct 02, 2013 9:45 pm
[quote="pvr"]
[quote="snipez999"]
Actually-touching all the wood I can find-it has been one of my most reliable cars!!
Currently :
2012 Audi RS4 (B8)
Previously :
Don Coffey
Post by Don Coffey » Wed Oct 02, 2013 10:16 pm
[quote="sid10"]
Cheers for the suggestion, although I'm wondering about mixing it 50/50 with Tarmac for the driveway and then block for the parking areas and pathway around the house.
Don
Don Coffey
Post by Don Coffey » Wed Oct 02, 2013 10:22 pm
[quote="Nat"]
Hi,
Block paving no issues if foundations done properly and if it sinks you just lift the blocks and pack more sand under it, so very easy to repair.
Weeds can be a problem, regular spraying is the answer.
Make sure the outer bricks/blocks/sets are properly fitted and set as thats what holds the rest in place.
Regards,
Nat.
Cheers Nat, yes, a largish driveway, but seemed like a good idea when the digger was around doing the land scraping....should have just taken the shortest route to the road!
Taken from Apple maps and not great quality, but you get the idea.  The photo is a couple of years old, I should really get some fresh ones, especially as I can get my own aerial shots.
Don
Caesium
Post by Caesium » Fri Oct 04, 2013 11:36 am
Definitely block pave it.
Tarmac is pretty awful stuff, it melts in summer and can leave your shoes with a black deposit which will end up all over the inside of your house.
The drive stuff is never as resilient as highway tarmac and weeds will grow through it eventually, especially around the perimeter. Just look at pavements for an example of penetration of plants.
Block paving does have disadvantages, as weeds can take hold between the pavers, but you can control them easily by dosing with a persistent herbicide once every 6 months or so.
Both drives can sink and settle over time, but with block paving it's easier to remedy than with tarmac.
Blocks can be removed and replaced with no visible disturbance, whereas tarmac cannot.
You can put lights along the perimeter blocks too, and that looks really nice at night.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
535dboy
Post by 535dboy » Fri Oct 04, 2013 11:41 am
[quote="Don Coffey"]
Don
I guess you didn't want to show us the swimming pool and tennis court you've had built since right!?
Currently :
2012 Audi RS4 (B8)
Previously :
Don Coffey
Post by Don Coffey » Fri Oct 04, 2013 12:06 pm
[quote="535dboy"]
:)) :)) :)), I wish, it is an old farm, so a number of out buildings have already come down, and a couple of the stone ones are straying but need work before I can think of anything else.  Tennis courts will never happen, and a swimming pool will probably be nothing more than a pipe dream for a few years at least.
Unless of course you would like invest some of your wealth in irish property?
Don
Don Coffey
Post by Don Coffey » Fri Oct 04, 2013 12:09 pm
[quote="Caesium"]
Some food for thought and compelling arguments for block, I will take these on board.
Don
535dboy
Post by 535dboy » Fri Oct 04, 2013 12:25 pm
[quote="535dboy"]
Don
I may have a good Irish surname but those rootes along with my welsh and Scottish(!) are now cut
Currently :
2012 Audi RS4 (B8)
Previously :
