Sat Nav has totally disappeared from menu :(
Re: Sat Nav has totally disappeared from menu :(
Post by X5Sport » Tue Nov 26, 2013 5:17 pm
The 4x4 light is easy to sort.  That one is a normal warning when the battery is dissed.
Start the engine and moving slowly (just creeping is all you need as it saves loading the steering) forward move the steering from lock to lock.
Have you tried loading an earlier version of the OS firmware?  Sometimes that works on apparently 'bricked' nav computers.
Veeru
Post by Veeru » Tue Nov 26, 2013 9:26 pm
Thanks Richard
I've also tried leaving the original maps DVD in for the past few days but that hasn't done anything.
How can I get hold of a copy of the old software? And is this easy to load?
V
x5dom
Post by x5dom » Fri Aug 22, 2014 2:37 pm
Just to update (sorry for delay!)
After having had my mkIV dvd unit checked by two separate places, both returning it with a full bill of health, I came across this guy... Baris at http://www.carphonics.co.uk/. He's based in Enfield, so a short drive from Jn 25 of the M25.
The great thing with Carphonics is they have the full kit to benchtest the whole system and find the culprit. My problem was the TV tuner. Guess the whole lot (HU, dvd drive, BM54, tv unit etc) are all interlinked, so the TV tuner was causing the simplified menu sans navigation. Bought a replacement upgraded tuner from Carphonics and happy days again.
I found Baris very professional and careful when removing and refitting  8)
If you are experiencing any sat nav problems, do not hesitate to contact him, info@carphonics.co.uk or 07958 499151
HTH someone get theirs back to tickety boo
_________________________________________________________________________________________________
2005/55 E53 3.0d Sport - Sterling Grey/Dakota Black - Sports Plus Pack - 168 20s - Comms Pack - and many toys!  :)
Toy: '95 VW Corrado VR6
Veeru
Post by Veeru » Fri Sep 12, 2014 12:39 pm
Hi all
Im still struggling with this issue, at a total loss now
Cant even seem to find out how to check my firmware version?
Has anyone found a solution?
I had a thought of swapping the sat nav unit thats in the boot with my other x5's which is currenty working? is this recommend...or could i possibly end up with two not working?
any help would be appreciated.
cheers
chrisn7
Post by chrisn7 » Fri Sep 12, 2014 1:18 pm
If you have TV and nav in the car, the video is controlled by the nav. If you unplug the nav, then video switches to being controlled by the TV module. It is the TV module that displays the all blue screen, and the menu will not show the nav option. Therefore either the nav or its power supply has failed / is unplugged.
