CHANGING 3.0d breather assembly
Re: CHANGING 3.0d breather assembly
Post by x555 » Tue Nov 23, 2010 7:46 am
x555
Post by thedweeb » Tue Nov 23, 2010 11:35 am
Dweeb
thedweeb
Post by Hits553 » Tue Nov 23, 2010 2:04 pm
My 2005 3.0d had its 3rd oil change recently and the indy i used todl me that i need this part changing, but they didnt have it in stock so i need to take it back in. He qutoed £220parts and labour which includes breather value, air filer and fuel filter.
Does this sound about right?
Hits553
Post by x555 » Tue Nov 23, 2010 9:23 pm
Dweeb[/quote]
Thanks fella
Ironically i had been searching real oem over and over but couldn't find the damn thing and then after posting i finally found that it was in the 'Fuel Preparation System' section:
x555
Post by x555 » Tue Nov 23, 2010 9:28 pm
Does this sound about right?[/quote]
I would say that sounds ok as the parts would be around the £100 mark and there is a bit of time/labour involved in getting at them.
x555
Post by thedweeb » Wed Nov 24, 2010 11:25 pm
Sounds about right but why dont you do it yourself and put the £120 in your pocket.
thedweeb
Post by Hits553 » Fri Nov 26, 2010 9:39 am
Hits553
Post by x555 » Fri Nov 26, 2010 9:15 pm
I changed mine today along with the filter and it was the updated version...my build date was August 04 so either mine has been upgraded(which i don't think so to my knowledge) or perhaps x mans was replaced by an older version..... strange!x man wrote ..... @ pvr the build date on my x5 is march 2005 and it did not have the modified breather filter fitted to it,
so not sure when in 2005 the modified filters were fitted.
I was expecting mine to be the older type.
@ Bazzyboy you mentioned the two part numbers in your op so i only bought one being the new housing assembly with filter(as i thought i had the old one)had i thought that i had the new one i obviously would have only ordered the other part.
As for the other part 11127799366 for £19 i take it that is the seperate plastic part with two holes in the top (in x mans picture)....sorry for the lame question but if that is the filter and not the other round part that is part of the housing then it means i have a spare upgraded filter housing.
x555
Post by bazzyboy » Fri Nov 26, 2010 9:23 pm
someone may have changed the breather already, some good dealers do advise them
u could sell the upgrade part to someone on the forum & they then only need to buy the filter
ps well done on doing it ur self
did u notice any benfit bye the way
bazzyboy
Post by Sanj » Fri Nov 26, 2010 9:27 pm
Oh and yes - any benefits?
Sanj
Post by x555 » Sat Nov 27, 2010 8:16 am
did u notice any benfit bye the way[/quote]
Thanks bazzyboy...thats what i was thinking that it would benefit someone with the old type breather
@Sanj.........I will charge you extra for it already being broke in for you........you feckin magpie.......btw no offence there geordies
x555
Nige
Post by b11nnl » Wed Jan 12, 2011 10:04 am
Help would be appreciated
b11nnl
Post by x555 » Wed Jan 12, 2011 10:16 am
Two 13mm nuts iirc and the whole assembly slides forward and out and then you can get access to the allen bolt at the rear
I'm just about to go in the garage and do exactly the same job ...again
x555
Post by b11nnl » Wed Jan 12, 2011 10:27 am
Good luck with your one.
b11nnl
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
