	upgrading bulbs on the ring lights
				bigshout
Re: upgrading bulbs on the ring lights
Raj, do you have any pics of your halos in day light and at night. That one hell of a price to charge for LED markers.
I've also been told M-Tech2 LED markers are also high grade and states as being the bridghtest, can be bought from HID direct for around £60.
[quote=""Raj""][quote=""535dboy""][quote=""Raj""]I have replaced mine with AE V3 LEDE bulbs and there are very bright and white (but expensive). Can get cheaper ones if you want. They are not difficult to replace but do flicker on start-up (but I don't mind as it only lasts a second or so and I quite like it....lol).[/quote]
Where did you get these?
I'm struggling with the SSDD ones.
Seems to be two LED bulbs that presumably I need to line up with something as the outer rings aren't really showing at all ![/quote]
I bought mine direct from http://www.angelibright.com/. Was quick shipping.
You shouldn't have a problem with Teddy's though. The bulbs need to be properly in the holders but will light both rings equally. The led bulb should be right near the fibre optic ends of the rings.[/quote]
[quote=""bigshout""]Raj, do you have any pics of your halos in day light and at night. That one hell of a price to charge for LED markers.
Will be picking up the X tomorrow so will take some this weekend.
tbh, I bought mine quite sometime ago before the M-Tech2's came out, etc.
				d8ean
[quote=""Jalf""]I changed mine with a set of PIAA H8 LEDs, no errors or troubles at all
would those work on a 2006 x5?
[/quote]would those work on a 2006 x5?
- Jalf
What bulbs are they on your X5 dean? these are H8 bulb fittings.
I've just checked the realoem site and your X5 looks like it uses H7 bulbs, you can get bright white H7s easily but from my experience they are prone to exploding, leaving you with a headlight full of broken glass I'm sure there will be an LED alternative though.
 I'm sure there will be an LED alternative though.-
				d8ean
[quote=""Jalf""]What bulbs are they on your X5 dean? these are H8 bulb fittings.
I've just checked the realoem site and your X5 looks like it uses H7 bulbs, you can get bright white H7s easily but from my experience they are prone to exploding, leaving you with a headlight full of broken glass I'm sure there will be an LED alternative though.[/quote]
yea im guessing mine are the older H7 bulbs? being a 2006 car.
i dont want aggro from broken exploding bulbs, looks like i'll just have to wait til someone brings out a LED replacement
 I'm sure there will be an LED alternative though.[/quote]yea im guessing mine are the older H7 bulbs? being a 2006 car.
- 535dboy
Teddy sent new bulbs out for me and they fit much better. Top service there.
Thanks also to Jalf for the pm's
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
						2012 Audi RS4 (B8)
Previously :
[quote=""d8ean""][quote=""Jalf""]What bulbs are they on your X5 dean? these are H8 bulb fittings.
i dont want aggro from broken exploding bulbs, looks like i'll just have to wait til someone brings out a LED replacement [/quote]
Dean, do you have xenons? The H7 bulb is the standard headlight bulb. The rings are lit by a halogen bulb and you can get LED replacements already.
[/quote]Dean, do you have xenons? The H7 bulb is the standard headlight bulb. The rings are lit by a halogen bulb and you can get LED replacements already.
[quote=""535dboy""]Teddy sent new bulbs out for me and they fit much better. Top service there.
Thanks also to Jalf for the pm's[/quote]
Teddy is very big on customer service. Glad you got sorted.
Took some quick pics of the AE LED units I have along with one of the HID kits fitted to the fogs.
Not the best pics tbh as it was just getting dusky so camera couldn't quite pick up the brightness of the AE's.
				d8ean
[quote=""Raj""][quote=""d8ean""][quote=""Jalf""]What bulbs are they on your X5 dean? these are H8 bulb fittings.
Dean, do you have xenons? The H7 bulb is the standard headlight bulb. The rings are lit by a halogen bulb and you can get LED replacements already.[/quote]
yes i have xennons already - good news about the LED bit - which one and where do i buy from ?
[/quote]Dean, do you have xenons? The H7 bulb is the standard headlight bulb. The rings are lit by a halogen bulb and you can get LED replacements already.[/quote]
				finnie
Raj is that the non xenon upgrade from Teddy? Looks very good indeed. I really like the look of the halo's too!
[quote=""d8ean""]
yes i have xennons already - good news about the LED bit - which one and where do i buy from ?[/quote]
There are various ones on the market. M-Tech ones are supposed to be very bright (on par with mine), mine were very expensive but I got mine before all the others came out and the only other person I would go with is Teddy at SSDD motorsport. I will find out a price for you and PM later.
[quote=""finnie""]Raj is that the non xenon upgrade from Teddy? Looks very good indeed. I really like the look of the halo's too![/quote]
I have OE xenons (but hav replaced the OE bulbs with 6000k), AiB LED angel eye bulbs and replaced the OE foglight bulbs with one of Teddy's HID kits. The front end looks so much better.
