[quote="X5Sport"]that's a pic of a capacitor.....not a resistor. Good suppressor though.
R
That's one thing I know nothing about buddy... ???
But it does the job. ;D
LED Tail Lights installed but have some issues
- Sanj
Re: LED Tail Lights installed but have some issues
mikem
Why not use the scanner and turn off the hot and cold bulb tests for them instead of fitting resistors ?
- Sanj
[quote="mikem"]
These help stop the bulbs flickering too.
But yes an idea - just that you lose a useful function of knowing when a bulb is out.
mikem
Sanj, is the flickering not a result of the bulb test ? My led angel eyes used to flicker untill I turned the lamp test off. I believe the test sends a small current through which isn't enough to light up the OEM bulbs but is enough to light the LEDs, hence the flicker.
- Sanj
No, this is the stupidly rapid flickering you get.
The start-up bulb test is just for the car to work out if 'all systems are go'.
