3.0d cranking taking longer....
drb5
Re: 3.0d cranking taking longer....
Not necessarily.
Our E60 had iirc, two or three glow plugs away and ran it till we sold it, without any troubles.
They tend to make firing up harder and thus the turning over longer
2004 Sapphire Black 3.0d Sport Auto, 168 style 20's, silver 4.8IS grille, tinted back windows, black leather with titanium trim, sat nav, PS2 media center with hard drive, TV's in headrests, TV in motion, Dice Silverline and a few others toys!
- x555
[quote=""drb5""]Not necessarily.
They tend to make firing up harder and thus the turning over longer[/quote]
Agreed
but Blo2was was saying that it happens on a warm start but not on a cold....strange!
Agreed
BL02WAS
Surely that glow plugs wouldn't be an issue if engine warm??? Serviced very recently with new oil filter, air filter, oil etc, no plugs though!! Any ideas??
drb5
Tis indeed...missed the bit about only when warm.
Wondering if the alarm problems have been sorted now, with the battery having been replaced...
- Turks
- Contact:
[quote=""drb5""]Our E60 had iirc, two or three glow plugs away and ran it till we sold it, without any troubles.[/quote]
Note to self: Don't buy a car from drb5
Just kidding mate, I just try to sort known problems out as soon as they arise or they could have a knock on effect on other components and cost more in the long run...
Turks.
Turks.
Present:
Past:
Past:
drb5
Lol, i know i know.
It was actually the opinion of our local garage to leave them till we actually HAD a problem. They were found when it was plugged in to check a flat spot, which turned out to be a MAF....this WAS replaced.
We've lernt over the years, unless there is a definate problem which you can't live with, then you fix it. Too many others things go wrong when disturbing bits.
- x555
I reckon it could be to do with the rail pressure control at start mate
perhaps a sensor!
BL02WAS
Well x555 how have u come to that conclusion??? The force is strong in you!!! I think you might be right!!
Haa
thedweeb
[quote=""x555""][quote=""thedweeb""]I've been watching this post and I didnt think it would be the battery. As for what it is I'm not sure either. When did you last have the engine serviced/filters changed ? may something as simple as that.[/quote]
Thats handy to know after the battery has been purchased
Yea I know but I'm no expert, he would still of got one
thedweeb
[quote=""x555""]I reckon it could be to do with the rail pressure control at start mate
perhaps a sensor![/quote]
I think its fuel as well.
justin0
Had the same a while back and it was an injector problem, leak off excessive causing low rail pressure during cranking. Get a code reader and see if "RAIL PRESSURE LOW DURING CRANKING" is shown. It is then a case of diagnosing the offending injector with a fuel leak off test.
Hope this helps.
Hope this helps.
2003 X5 3.0d Sport, Silver, Black Leather, Nav, Intravee & Mirror & Lock Mods, TV, DTUK Chip, Remote Heating.
GSXR 1000 K2, 150 BHP @ R/Wheel, P/Commander, TRE, Arrow 60mm Carbon/Titanium Sys, Brembo, Talon, Galfer Brakes, Rear Sets.
Golf GT TDI
Golf GT TDI
BL02WAS
Justin, did you have same problem with it starting perfectly when cold, then once warm taking 2 to 3 seconds to start???? It only does it when engine is warm.
BL02WAS
Any1?? Car gone in today to garage, so should find something out by the end of today!!
BL02WAS
Garage think all signs point to an injector. Reckon best thing to do is live with it until I start getting a misfire etc at idle, then perform leak test to find offending injector, then replace. The cost to test injectors is 35 pound each, 6 need testing before you start otherwise!!!
- x555
And the injectors are about £200+ a pop mate i know because i had two replaced on my last x.
