Another question re rear pads - I believe for 3.0d I need pads for 320mm disk brakes. 345mm disks fitted to 4.0d or sd model?
P.S. apparently both textar and Pagid made by Tmdfriction
Brake pads
- acideraser
Re: Brake pads
2011 X5 xDrive30d SE Platinum Grey 20" 336 alloys
Re: Brake pads
Realoem shows 34216793247 as the rear disc part number for the 40d which is a 320mm*20mm ventilated disc.
The front one is 348mm*30mm, part number: 34116793244 on the 40d
Front 30d is a 332mm*30mm 34116793245
Rear 30d is a 320mm*20mm, part number 34216793247 the same as the 40d.
It looks like only the fronts are different. No reference made to the trims, only the engines.
