Page 2 of 3
Re: X5 2002 4.6is sat Nav and sound problem
Posted: Sun Feb 26, 2012 7:37 pm
by gobiman
Before replacement, just worth taking the disc out and re-inserting a few times. I had this problem earlier in the year ie it defaulting to non Sat Nav screen. Taking the disc out and putting it back in a few times cured it.
Posted: Sun Feb 26, 2012 10:38 pm
by Moh153
Il give that a try mate as the previous owner had an ICE system in it and didn't use the sat Nav or the front widescreen unit
He used some other make of headunit and sound system
Posted: Mon Feb 27, 2012 4:59 am
by Denis O
[quote=""Moh153""]Il give that a try mate as the previous owner had an ICE system in it and didn't use the sat Nav or the front widescreen unit
He used some other make of headunit and sound system[/quote]
Ah ha. So someone has been pulling wires about and changing all manner of things when using a different ICE system. In that case I'd start by checking all the connections to the screen and the Nav computer are correct.
Posted: Mon Feb 27, 2012 11:31 am
by dirtymonkey29
Good thought Dennis but the OP has tried a mk4 unit which worked so I would say nothing wrong with wiring etc. it's more likely that the nav unit is knackered which I assume is why the previous owner fitted aftermarket.
Posted: Mon Feb 27, 2012 12:01 pm
by Denis O
[quote=""dirtymonkey29""]Good thought Dennis but the OP has tried a mk4 unit which worked so I would say nothing wrong with wiring etc. it's more likely that the nav unit is knackered which I assume is why the previous owner fitted aftermarket.[/quote]
Whoops. That'll teach me to go straight to page 2 and not read all of page 1 first
As you were chaps...
Posted: Mon Feb 27, 2012 4:58 pm
by Moh153
Thanks guys
The only reason the previous owner used a aftermarket unit as the car was a demo car and had £20k worth of ICE so changed the unit
Good thing is that he got the whole car dynamat'd so it's quiet inside with the sound proofing
Now on the hunt for a mk4 unit hopefully lol
Posted: Mon Feb 27, 2012 5:48 pm
by dirtymonkey29
Think there were a couple on here for sale.... Raj and someone beginning with "n"
I have a memory like a goldfish
Posted: Mon Feb 27, 2012 5:49 pm
by dirtymonkey29
N1k85
Posted: Mon Feb 27, 2012 7:24 pm
by n1k85
Not mine I'm afraid, I only had the Standard CD player. Got £100 for it on eBay though!
Posted: Mon Feb 27, 2012 9:50 pm
by dirtymonkey29
I thought you got the 'ooligan
Posted: Mon Feb 27, 2012 10:34 pm
by n1k85
I do, but I used to have just a CD player before I fitted it
Posted: Mon Feb 27, 2012 10:36 pm
by dirtymonkey29
Ah yeah now I remember
Posted: Wed Feb 29, 2012 9:14 pm
by Moh153
So I sen the bm54 to get repaired and chap rang me to let me know the bm54 is working perfect
The problem is the Dsp amp under the cd changer
Is that an expensive fix?
Posted: Sat Mar 03, 2012 12:28 am
by Moh153
So the dsp amp ( black ) had 3 channels burnt out so now fixed so should get it back monday
Posted: Thu Mar 15, 2012 11:48 pm
by Moh153
so the sound problem is sorted up and running with the dsp sound
now the sat nav is sorted to got a replacement mk3 unit with europe maps
now the problem ive got is that its stuck in another country on the unit i think its in brussels and the voice navigation is not in english either
so if i put a destination in which is a few miles away it shows that its over 400 miles away as it thinks its in brussels
in the top right corner where GPS is supposed to show up it doesnt so does it mean i might need a new gps antenna??
any advice chaps?
