Simple question about windscreen washers
gchristofi
Post by gchristofi » Thu Feb 16, 2012 7:40 pm
Hi Jonny
Mine has 2 pumps (2004 facelift). Easily accessible on the washer bottle itself. Push stalk away to 1st position activates the rear wiper. Push away and hold in next position operates the rear washer. Pull back to middle turns off rear wiper again.
Pulling stalk towards you and holding should operate front screen wash and high speed wipe until released. If your headlights are on, this also operates their washers every 5th go.
gchristofi
Post by gchristofi » Thu Feb 16, 2012 7:44 pm
Now, reading your description of what is happening, I suspect a wiring problem rather than swapped pipes. Could be at switch but worth checking at washer bottle too.
jaynana
Re: Simple question about windscreen washers
Post by jaynana » Thu Feb 16, 2012 8:06 pm
[quote=""jonnyivy""] when I pull the lever back it only washes the rear screen.
On the other hand, when I push lever fully forward the washers for the front work okay ( along with the headlight washer too )
sounds like simply the pump wires or the pipes swapped.
jonnyivy
Post by jonnyivy » Fri Feb 17, 2012 8:32 pm
Weather permitting, the bonnet will be lifted tommorow and I'll have a look.
Thankyou for guiding me in the right direction,
will let you know what I find,
Jonny
Virgin owner of X5 3.0 D 2003 ( getting to know her better now )(thinking of a long-term relationship now )( sadly  now divorced !! )( 4 years later...met the newer model and happy again )
jonnyivy
Post by jonnyivy » Sat Feb 18, 2012 2:33 pm
SORTED,.. thanks for your help, especially last 2 posters.
Had a look at the 3 pumps on side of washer fluid container,..took the 2 pumps that were side by side and swapped the wiring plugs,.. bingo,.. all working as they should
On hindsight, my car had a new turbo fitted last year under warranty and I suspect this resevior was removed for the job.
Thanks again,.. great forum,
Jonny
jaynana
Post by jaynana » Sat Feb 18, 2012 3:49 pm
[quote=""jonnyivy""]SORTED,.. thanks for your help, especially last 2 posters.
Jonny[/quote]
good stuff mate, feels good i'm sure - to get something fixed urself:)
Post by X5Sport » Sat Feb 18, 2012 5:34 pm
Says a lot for the turbo fitter if they put the plugs back in reverse... :headbang:
Glad it's sorted and was that simple.
gchristofi
Post by gchristofi » Sat Feb 18, 2012 9:49 pm
Nice one, better the wiring at the bottle end than the stalk, result...
