Page 2 of 2
Re: Souping up the reversing lights...any ideas?
Posted: Fri Jan 20, 2012 3:05 pm
by jaynana
[quote=""lezmtaylor""]I always thought that reverse lights had to be non beaming and 21w max,
Lez[/quote]
says who? is that a law?
Posted: Fri Jan 20, 2012 7:41 pm
by storminmike
[quote=""fenj66""]the reverse light wire can be found just under the removable boot floor between the spare wheel and the rear of the car. iirc its in a loom covered with black tape that just needs removing to expose all the wires.
if it were me fitting high power lights for reverse i would use heavy duty cable through a relay and just go from the battery posts with a suitable in line fuse.[/quote]
Cheers for the find the cable tip
Posted: Fri Jan 20, 2012 7:49 pm
by storminmike
[quote=""Raj""]Just try not to reverse anywhere then no problems...lol.
Seriously though, I replaced my standard bulbs with xenon look ones but they still probably aren't bright enough for what your after I guess.
What fitting a reversing camera instead?[/quote]
Camera needs a screen...I have no screen :D ,,,and night vison cameras are a tad pricey :o
Posted: Fri Jan 20, 2012 7:51 pm
by storminmike
[quote=""jaynana""][quote=""lezmtaylor""]I always thought that reverse lights had to be non beaming and 21w max,
Lez[/quote]
says who? is that a law?[/quote]
I'm sure there is position legislation for certain lights....in fact I was watching (again) a car is born undergoing an SVA test....no mention was made of reversing lights but then it's an edited show
aha
it's here
http://www.legislation.gov.uk/uksi/1989 ... le/14/made
Number:Not more than two (my 2 would make it 4 :x
A reversing lamp bearing an approval mark:No requirement(b) A reversing lamp not bearing an approval mark:The total wattage of any one reversing lamp shall not exceed 24 watts
Posted: Fri Jan 20, 2012 8:31 pm
by fenj66
hmmm, to keep within the law then, if your thinking of fitting fog type reverse lamps, it might be wiser to fit them independent of the cars reverse lights, and fit a toggle switch to turn then on only when required ie, down dark unlit areas.
Posted: Fri Jan 20, 2012 11:49 pm
by Rebeccabuck
[quote=""storminmike""][quote=""Raj""]Just try not to reverse anywhere then no problems...lol.
Camera needs a screen...I have no screen :D ,,,and night vison cameras are a tad pricey :o[/quote]
Yeah and mines always dirty! Reckon it would be hard to see through mud!!
Perhaps my lights just need cleaning lol...
Posted: Sat Jan 21, 2012 1:38 am
by Raj
We can fix the screen issue as I have one you can purchase..... :rofl: :poke:
Posted: Sat Jan 21, 2012 1:59 pm
by storminmike
[quote=""fenj66""]hmmm, to keep within the law then, if your thinking of fitting fog type reverse lamps, it might be wiser to fit them independent of the cars reverse lights, and fit a toggle switch to turn then on only when required ie, down dark unlit areas.[/quote]
It starts to get messy then I suppose as there's always the risk (as per some waggons :x ) leaving it on. Plus to be within the law you need an indicator up front to tell you it's on...I think
I doubt plod actually knows there should be only 2. The current plan (if I find the right type of lights) is to wire them through a relay so they can never be left on when going forward. Bung an accesable fuse in line in the rear to disable if required
Posted: Sat Jan 21, 2012 3:22 pm
by jaynana
[quote=""storminmike""][quote=""fenj66""]hmmm, to keep within the law then, if your thinking of fitting fog type reverse lamps, it might be wiser to fit them independent of the cars reverse lights, and fit a toggle switch to turn then on only when required ie, down dark unlit areas.[/quote]
I doubt plod actually knows there should be only 2. The current plan (if I find the right type of lights) is to wire them through a relay so they can never be left on when going forward. Bung an accesable fuse in line in the rear to disable if required[/quote]
yep, relay is what i'd do. if the max wattage is regulatory MOT guys might not like extra lights flashing on their eyes when testing reverse lights. best to bung a toggle switch next to that fuse as well. so that u can knock it off when not in need.
Posted: Sat Jan 21, 2012 7:41 pm
by storminmike
[quote=""Raj""][quote=""storminmike""][quote=""Raj""]Just try not to reverse anywhere then no problems...lol.
We can fix the screen issue as I have one you can purchase..... :rofl: :poke:[/quote]
well if you can supply...and fit...and add/fit a camera for the price of two cheap (£30)halogen fog lights then you've got a deal 8-)....even better if you threw blu tooth in ;)
