Page 2 of 4
				Re: scanner 1.4.0
				Posted: Mon Nov 14, 2011 9:42 pm
				by x555
				Just posted on the other thread malc
				Re: scanner 1.4.0
				Posted: Wed Nov 16, 2011 3:55 pm
				by malc1950
				scanner 1.4.0 drivers and software will work on windows 7, as i now have it on my netbook with windows 7
				Re: scanner 1.4.0
				Posted: Wed Nov 16, 2011 4:08 pm
				by malc1950
				My friend has a Scanner 1.4 0, if anybody want there park heater enabled or alarm settings changed or any other settings changing he will do it for £20, he lives in Manchester
				Re: scanner 1.4.0
				Posted: Wed Nov 16, 2011 5:04 pm
				by SimplyRed
				[quote=""malc1950""]My friend has a Scanner 1.4 0, if anybody want there park heater enabled or alarm settings changed or any other settings changing he will do it for £20, he lives in Manchester
Will he travel to London?  I assume not.
Anyone in London to do it?
				Re: scanner 1.4.0
				Posted: Wed Nov 16, 2011 5:11 pm
				by malc1950
				I could ask him then put my fingers in my ears !!!
				Re: scanner 1.4.0
				Posted: Wed Nov 16, 2011 10:28 pm
				by kkodal78
				i ordered one but we'll see on the windows 7 compatibility.
				Re: scanner 1.4.0
				Posted: Fri Nov 25, 2011 11:26 am
				by Ubatoid
				If you having issues running the programme on win 7 try right clicking on the icon and choose "troubleshoot compatibility" try running the programme in windows xp mode or windows 95. This usually works.
				Re: scanner 1.4.0
				Posted: Fri Nov 25, 2011 5:49 pm
				by Waka
				Mine works fine on Win 7.
				Re: scanner 1.4.0
				Posted: Sat Nov 26, 2011 2:38 pm
				by malc1950
				mine works fine with windows 7 also
				scanner 1.4.0
				Posted: Sat Nov 26, 2011 5:51 pm
				by kkodal78
				will give it a try tonight
				Re: scanner 1.4.0
				Posted: Wed Jan 25, 2012 10:56 pm
				by garioch
				im having a bit of trouble with mine, just got it tried installing it to laptop, and keep getting stuck when trying to install driver, using xp, the window for installing new hardware pops up, click install from disc, then it says no driver update on cd...
im stumped
 tried to follow the pdf instructions to a tee. Bought it from OBD master on ebay, anyone else bought from him and managed to get it working?
				Re: scanner 1.4.0
				Posted: Thu Jan 26, 2012 12:01 am
				by jaynana
				[quote=""garioch""]im having a bit of trouble with mine, just got it tried installing it to laptop, and keep getting stuck when trying to install driver, using xp, the window for installing new hardware pops up, click install from disc, then it says no driver update on cd...
im stumped
Cheers[/quote]
i installed the scanner last week. is this what you see in the folder where you're hoping to pick up the driver from?
also it should be XP Service Pack 2 or 3 (not 1).
my unit was from below not the same source as yours, but unlikely to be different..
http://www.ebay.co.uk/itm/310249608189? ... 2615wt_974
				Re: scanner 1.4.0
				Posted: Thu Jan 26, 2012 12:57 am
				by gchristofi
im stumped
Cheers[/quote]
Hi garioch.  I got from the same supplier and the issue you might be having is that you probably can't find a folder with those drivers in.  This is because the software you need (both scanner and FTDI drivers) are inside a .rar file called "bmwscan_140.rar"  .  This .rar file needs to be extracted just like a zip folder then you will be able to see the actual software and drivers.
If you don't already have a program that unpacks .rar files, you can download a free one from
http://www.download.com.  as per the following link.
http://download.cnet.com/The-Extractor/ ... ag=mncol;1
hope this helps.
				Re: scanner 1.4.0
				Posted: Thu Jan 26, 2012 8:34 am
				by garioch
				Thanks for the replies, to confirm I have xp sp3.
Gchristofi, what folder did you find the .rar file in?
I'll have a look after work and take some screenshots to let you see what I'm seeing.
				Re: scanner 1.4.0
				Posted: Thu Jan 26, 2012 10:24 am
				by gchristofi
				[quote=""garioch""]Thanks for the replies, to confirm I have xp sp3.
I'll have a look after work and take some screenshots to let you see what I'm seeing.[/quote]
On the mini CD in the "car soft" folder
